Samsung LCD TV no picture backlight on no 12v at tcon
    hi
    i have a samsung lcd tv
    it powers on with sound and backlight but no picture
    all voltages from PS are good 12v 3.3v and 5v
    whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
    i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
    no 12v at the tcon fuse
    i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
    the odds of having 2 main boards with exact same problem is rare but could happen
    could this actually be a bad tcon board? ..maybe is shorted out and not allowing main board to send the 12v?..or is this not a possibility.
    thank you
    Re: Samsung LCD TV no picture backlight on no 12v at tcon
    i think issue may actually be tcon...if i remove the tcon cable from the main board i now have the 12v at main board check point....so maybe tcon is shorted out which causes to lose 12v at main board to tcon?
      It was faulty tcon causing main board to shut 12v off
      Replaced tcon ..$8...now works great
