Thread Tools | Display Modes |
#1 |
City & State: zurich
My Country: switzerland
I'm a: Knowledge Seeker
![]() Hi All,
Ive just pulled apart a bowers & wilkins sub. The power board is covered in crappy chemi con SMG series caps. A couple are leaking and some others have ESR levels above manufacturer spec. Please any advice would be dearly appreciated. I want an alternative at least 105degrees longer life caps (the smg are 85 degrees 2000hrs) Ive been reading and getting more confused, ppl saying you need to match the same ESR and spec correctly. Ive attached pics - the little black caps are the SmG - not sure if i need low esr caps or general purpose etc |
#2 |
The Boss Stooge
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
![]() None of those *appear* bad. As far as leakage, if you're referring to the white stuff around the bases of the larger ones, that's not leakage....it's glue.
As a rule, UCC caps are pretty good, their only 'troublesome' series were KZG and KZJ.
__________________
<--- Badcaps.net Founder & Owner Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#3 |
![]() Ive tested all of the caps and a number are faulty.
My main thing is a recommendation of which series of cap to go for in a brand like panasonic, nichicon, rubycon ( with at least 105 degrees and longer lifespan) |
#4 |
City & State: Europe
My Country: some shithole run by Israeli agents
![]() i tend to just put panasonic FR in just about anything these days
#5 |
The Boss Stooge
#6 |
![]() Thank you! Ill order some panasonic FR series for the recap (will there be any issues given that they are low esr?
Anyone have any experience with the Panasonic EEUTA1 they are rated at an insane 125 degrees! |
#7 |
![]() philips make 135degree caps,
i dont think the esr and ripple are good on the really high temp stuff though - they are generally intended for stuff like gas ignitor units. |
#8 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() SMG is UCC/NCC's general purpose series, not low quality. And it looks to me like they are being used appropriately.
That said, just about any of the good brands' non-aqueous low impedance series should do well: UCC/NCC LXZ series Panasonic FC series (is FR the newer non-aqueous low impedance series?) Nichicon PW or PA series Rubycon YXF These brands' long-life aqueous series are all excellent, but aqueous parts tolerate ambient heat a little less well, and these series' lower impedance is of no special benefit. So go with best price and availability of the series listed above, IMO.
__________________
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 7 5Ks, 1 8K, 8 10Ks, and 4 half marathons |
#9 | |
City & State: Maritimes
My Country: Canada
Line Voltage: 250V Split-phased, 60 Hz
I'm a: Hobbyist Tech
![]() Quote:
#10 | |
![]() Quote:
smg specs: https://www.digikey.com/catalog/en/p...mg-series/3646 rubicon: https://www.digikey.com/catalog/en/p...g-series/25454 the high and low frequency ripple currents appear to have significant differences in values between the SMG and YXG caps. Will it be an issue with stability or cause any issues if I replace all of the smg caps for the rubycon yxg? (its for a b&w subwoofer power board and amp board both of which are covered with chemi con SMG caps, 3 of which are faulty) - both the smg yxg are labelled as general purpose. thank you all for your kind patience Last edited by hansy; 11-19-2020 at 07:20 PM.. Reason: more detail |
#11 |
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
![]() You will probably alright using them ( this would not be my first choice but might be a third choice but it cost that drive my choice ) my first choice is United Chemi-Con KY / KZE / LXZ or second choice FR / FC ( size diameter and height make this choice for me sometime ) I find that this brand of capacitor are higher in cost. The smaller UF under 100 UF value of capacitor I buy a hundred of them at a time
Sometimes it what device I am working on and what brand of capacitor are already installed sometimes make that decision for me if I can still find that series or not Some Servo motor controller can be pick-e what type of capacitor that is used
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() Last edited by sam_sam_sam; 11-19-2020 at 08:57 PM.. |
#12 | |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() Quote:
I see that the picture of the PSU you showed is of the switching type. So if anything, YXG will probably do better than SMG due to having lower ESR... and also longer rated life. |
Thread Tools | |
Display Modes | |
