I have a VSX-D2011. Hard switch turns on the standby LED for just a couple of seconds. Sometimes longer about 2 minutes. During those time that the standby light is on I can switch on the receiver with all displays normal and relays click normally. Did diagnostics as per SM and everything passed, and suddenly turns itself off again. have to wait couple of minutes before I can get a standby light again. Suspected capacitor. Any suggestion where to look first? Primary Board? Regulator Board? or Controller. Thanks
Pioneer VSX-D2011 won't turn on
Re: Pioneer VSX-D2011 won't turn on
check the standby power supply, cn2004 pin 3 should have +5.6 voltsAttached FilesLast edited by R_J; 08-29-2014, 07:47 PM.
You could have a cold solder joint or other poor connections somewhere, when the amp is working try poking and taping around with a insulated stick, sometimes larger connections such as regulator ic's and interconnecting plug connections give poor connections. other than that I don't know what to tell you.
Correct me if I'm wrong, I have an understanding that the standby voltage is pre-regulator stage.that is why at this point I'm ruling out the Regulator Stage. Na 5.6V is present to all IC's VCC as well so a cold solder may be unlikely. Tried tapping it anyway but it didn't help. Thanks.
The standby circuit has its own regulator ic2001 that supplies ST+5.6v
Does the main power supply stay turned on when the amp quits? (+- 15, +-24 +- 5.6 etc)
Is the manual I uploaded the correct one?
If the main power supply stays on then it is still getting the (ac ry) signal from the cpu
Little bit of a bump of an old topic.
But i have an pioneer vsx d2011, which has a similar problem.
Receiver turns on, and then would randomly go on a 'reboot' tour. This happens random.
RJ, would you upload the schematic again? It won't open, and i think that i might find a workaround in there! All help is very appreciated!
