Old Belkin 54g router bottlenecking speed
    My ISP upgraded my service from 30 to 60 Mbps and replaced the modem with an Arris TM822. A PC connected directly to modem gets well over 60 Mbps (actually peaked at 100) but thru the router only getting 30. Router is running DD-WRT latest firmware. The 4 LAN ports are 10/100 auto negotiation and the PCs connect at 100. I am not using the wifi on this router right now and radio is off. I don't see any place in the router settings to fiddle with LAN speed so I am left to assume this old Blekin just can't go that fast. I realize that 100Mbps is a theoretical maximum and in real use will never have that much usuable bandwidth but I'd think it could still get up to 60Mbps. Looks like I'll need a better router.
    Re: Old Belkin 54g router bottlenecking speed
    Ah, I see the problem. Duh, I was right on top of it all along, in my face so to speak. The modem connects direct to my PC at 1000Mb/s. The old router can only do 100. Yep, time for a router with faster eth ports.
      make sure the replacement has lots of led's on it - you can never have too many led's
        I like LEDs. Especially blue ones. It's my favorite color.
          Everything is better with blue LEDs, apart from my Virgin Superhub...they really shouldn't use super in the name !
          I can recommend the d-link DIR-615, happily runs DD-WRT, does N band, has 4 gigabit ports...and it's cheap.
          http://www.amazon.com/D-Link-DIR-615.../dp/B000QD7B6W
            The above link you provided to Amazon says
            Interface Type: 4 Fast Ethernet LAN Ports (10/100)
            NOT gigabit.
            --- begin sig file ---
            --- end sig file ---
              My mistake, I use one at home, I thought it was gig ports.
              I was given it by Virgin Media when i upgraded to the 100mbit connection, they told me it was gigabit. i don't transfer files between PCs do i wouldn't ever see the bottleneck.
                DIR-635 is a 615 with dual band N and gigabit ports, decent little router, and you get 100MB/s file transfers across its switch
