Thread Tools | Display Modes |
#1 |
City & State: Bedok
My Country: Singapore
I'm a: Knowledge Seeker
![]() Symptom: Plug in DC magsafe showing green light and change to orange colour for battery charging. In this case, unit unable to power on when power button has been press. No fan spinning, no start up sound.
Step debug as below:- 1. Unit still unable to power on via power pad. 2. Failure remain the same after SMC reset. 3. Power Rails measure as below with only adaptor plug in (no Battery):- > PPBUS_G3H -- 12.57v > PPBUS_CPU_IMVP_ISNS -- 11.58v > PPDCIN_G3H -- 16.5v > PP3V42_G3H -- 3.42v > PP3V3_S5 -- 3.32v 4. Others power rails no voltage. |
#2 |
City & State: Valbonne, 06
My Country: France
![]() History of the machine? Known good 85W Magsafe?
Are you sure about this?
__________________
OpenBoardView — https://github.com/OpenBoardView/OpenBoardView |
#3 |
City & State: Bedok
![]() Is Known good 85W Magsafe, battery is charging when plug in.
#4 |
City & State: Bedok
![]() Voltage measure with only battery condition:-
> PPBUS_G3H -- 12.57v > PPBUS_CPU_IMVP_ISNS -- 11.58v > PPDCIN_G3H -- 0v > PP3V42_G3H -- 3.42v > PP3V3_S5 -- 3.32v > Others power rails no voltage. |
#5 |
City & State: Ames Iowa USA
Line Voltage: 120VAC 60Hz
![]() Do all fuses pass a continuity check?
#6 |
City & State: Italy
My Country: italy
![]() pp1v05_s5_mcp volt ?
#7 |
My Country: France
![]() PP1V05_S5_MCP doesn't exist on 820-2850. It's a 2010 model, there's no MCP.
#8 |
City & State: Bedok
#9 |
City & State: Bedok
![]() Latest measurement, Power Rails measure as below with only adaptor plug in (no Battery):-
> PPBUS_G3H -- 12.57v > PPBUS_CPU_IMVP_ISNS -- 11.58v > PPDCIN_G3H -- 16.5v > PP3V42_G3H -- 3.42v > PP3V3_S5 -- 3.32v > PP3V_S3 -- 3.32v > PP3V_S0 -- 3.30v > PP5V_S5 -- 5v > PP5V_S3 -- 5V > PP5V_S0 -- 5V > PP1V05_S0 -- 0V -- CPUVTTS0_EN -- 3.3v > ALL_SYS_PWRGD -- 0v Observation: 1. All_SYS_PWRGD should be 3.3v for system to boot up but in this case is 0V 2. Suspect U7600 (ISL95870) faulty, try change but failure remain the same. |
#10 |
Vinifera
City & State: Dilbeek
My Country: Belgium
Line Voltage: 230VAC
I'm a: Hobbyist Tech
![]() Macbook Pro i5 820-2850-A (2.4G)
Hi, i bought a defect motherboard and i'm not sure that the following components must be on the motherboard ? C5369 R5371 C5318 U5313 U5323 U5101 C5101 U3301 C3302 U3300 R3940 ? Can somebody help me ? |
#11 |
City & State: Bedok
![]() C5369 - No Mounted
R5371 - No Mounted C5318 - No Mounted U5313 - No Mounted U5323 - No Mounted U5101 - No Mounted C5101 - No Mounted U3301 - No Mounted C3302 - No Mounted U3300 - No Mounted R3940 - No Mounted |
#12 |
Vinifera
My Country: Belgium
![]() thx Terence
Thread Tools | |
Display Modes | |
