I2C Programming - How to ?
    can someone tell me more about i2c programming wich interface & software is used for.
    And the most important question is:
    Is it possible to read the i2c data from a device, to copy it to another device.
    The part wich i need programm is a TPS658621C
    https://pdf1.alldatasheet.net/datash...PS658621A.html
    here the dataheet, i already found the pins H4 and J2 for SDA & SCL for the connection ,but i dont know wich software and programmer is the right one.
    Thank you for support.
    Re: I2C Programming - How to ?
    are you sure that chip stores anything?
    the "A" version doesnt, it just has control registers that i assume are written when you power up the device.
      thanks for your support.
      Maybee i have to tell the whole story about it
      i have 5 pcb`s from that device wich are not starting.
      (Industrial device, same like a notebook with touch panel)
      Normally the starting sequence on power supply:
      beginn 0,3Amp raise up to 0,55Amp and then the devie Start by 1,4Amp
      by this 5 pcbs i had some different starting sequencenes and the pcbs are not starting.
      3 x starting sequences goes from 0,3Amp - 0,5Amp raise up to 0,9Amp
      (the TPS658621C goes really hot) and it fall down again to 0,3 Amp
      2 x starting sequences goes from 0,3Amp - 0,5Amp
      so i decided to try to change the TPS658621C with new ones
      The result was that all 5 pcbs are makeing now this starting sequences:
      Start with 0,3 Amp raise to 0,65Amp and fall down again to 0,3Amp
      All 5 pcbs make exact the same starting sequences after change the TPS658621C and also that ones wich goes hot(the TPS658621C) is not getting hot after change but not starting .
      SO my result from that experiment was that the TPS658621C must be programmed and i looked to the datasheet and i saw that 11programmable mods are written in datasheet, and also that this ic is programmable with i2c interface....
      I thought its like a MCU programming maybee, so i was searching for the correct programmer ect.
      Maybee iam wrong, but why all devices have the same starting sequences after change TPS658621C =?
      I never do this before(i2c), but i did some emmc programmings ect.
      Note:
      By one of that devices i had also a problem by starting process:
      starting sequence was 0,3Amp - 0,5Amp and not starting...
      after reflow the TPS658621C (balled) the device started normally
      Thanks for your support
