Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 03-17-2022, 02:16 AM   #1
Widget
City & State: New South Wales
My Country: Australia
I'm a: Knowledge Seeker
Default Repairing faulty ANKO AO8606 air fryer
We have an ANKO AO8606 air fryer that suddenly no power. I pulled it apart and probed the AC-IN, but wasn't getting voltage (or continuity from the plug to the PCB in the air fryer).
I dug further and found a thermal fuse in the middle. No continuity on the fuse (but continuity on the plug > fuse, and fuse > pcb. but no beep on the fuse itself.)
Now looking to buy a replacement fuse and heat-resistance sleeve to see if that fixes things.
Anyone know if this fuse will be ok?https://www.ebay.com.au/itm/18483244...YAAOSw7I9hK0S5
^ I can get 3x fuses (couple of spares) for $7, otherwise cheapest I've seen is 1x for $7.50 (Australian dollar)
Also, the heat resistant sleeve. Are these ok,
https://www.jaycar.com.au/high-tempe...sort=relevance
https://www.ebay.com.au/itm/32492254...0AAOSw6i1hsaA-
Widget is offline   Reply With Quote
Old 03-17-2022, 04:47 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Repairing faulty air fryer
the fuses you linked are o.k. if the fryer isnt using over 10A
just remember to not get the fuse hot while your fitting it - a classic noob mistake
either freeze it before soldering or clamp a pair of grips or something to the lead to take away the heat.
better yet - use crimp terminals.
stj is offline   Reply With Quote
Old 03-17-2022, 05:52 AM   #3
Widget
Thanks Stj ,
Quote:
According to the sticker, it's 240v, 1800w. So that should be about 7.5amps?
oh wow, thanks for the tip . The thermal fuse that was in there seemed to be crimped in,
I've actually been looking at getting a pair of crimpers and some terminals. Just a basic set like this
https://www.bunnings.com.au/supatool...inals_p6010367
or
https://www.supercheapauto.com.au/p/...=en_AU&start=1
Nothing flash, but should do the job for someone who doesn't do much electronic work ?
Thanks again
Old 03-17-2022, 09:02 AM   #4
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Quote:
You could do a quick check with your meter:
Measure from both live and neutral to ground (if it has one) to make sure it is open.
And then measure from live to neutral and make sure you have a sensible reading: for 1800w at 230VAC that would be around 30ohms for the heating element.
__________________
Per Hansson is online now   Reply With Quote
Old 03-17-2022, 09:51 AM   #5
Widget
Hey Per Hansson, thanks for the reply
not too sure what you mean. Here a pic of what IO'm looking at. A couple of the connectors have been removed during the teardown.
Old 03-17-2022, 11:23 AM   #6
Per Hansson
City & State: ----
My Country: Sweden
The wires are labeled, just measure the AC wires to the green/orange ground wire to make sure the readings make sense (no connection).
And between the AC leads something in the range of 1800w as I wrote above.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
