Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 03-31-2022, 03:39 PM   #1
leotron
City & State: Colonie
My Country: Offworld
Thumbs down [Stupid Question #2] Why we are still using 12v on the ATX power source?
As the title says do you think it would be useful for modern PCs to use more DC voltage ? I know you can compensate the lack of voltage giving more AMPs but still at this rate we should be using 36v at least. Also why we can't connect an badass AC turbine (110~220) inside the case?
Delete the thread if its garbage please.
Regards and thanks for you patience.
leotron is offline   Reply With Quote
Old 03-31-2022, 05:16 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: [Stupid Question #2] Why we are still using 12v on the ATX power source?
12v is easier to find in the ghetto .
Old 03-31-2022, 05:36 PM   #3
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
(1) There needs to be some intermediate voltage, and it will still be a double conversion (120/240 line -> 12V or whatever -> 1.5V or whatever the ICs need, and this wire needs to be really thick as it could need to deal with upwards 50 amps...). 12V is ubiquitous anyway and it's needed for hard drives and other peripherals anyway.
Note that in server farms they typically use 48VDC but this too is a historical number and may well could have been 36V. We should be focusing on using less energy anyway.
(2) There's no 120V fans due mainly to cost - to ensure that it meets grounding safety requirements.
eccerr0r is offline   Reply With Quote
Old 03-31-2022, 07:45 PM   #4
redwire
City & State: Alberta
My Country: Canada
Power mosfets in the 30V league are optimized for cost, use in laptops and motherboards, so you could go higher than 12V but not to 24V.
Intel's new ATX 3.0 standard (for 600W gaming video cards!) is still 12V. They added a connector but seem OK to go to 50A. Nobody likes the standard yet.
redwire is online now   Reply With Quote
Old 04-01-2022, 01:24 AM   #5
leotron
Thanks for the honest answers, maybe I forget that the big tech companies make money selling servers and such (BIG LEAGUE) desktop gaming pc it's just 5 dollars per piece if I recall correctly, the earning are in the ideas ("look i have an algorith or a diode that reduces 5w in pwr compsunsion, etc")
Another question: Wouldn't be cool if the GPU came with their own PSU ?
Old 04-01-2022, 04:24 AM   #6
diif
City & State: Midlands
My Country: England
Google's servers use 48v.
Why would it be cool, what's the benefit ?
diif is offline   Reply With Quote
Old 04-01-2022, 01:19 PM   #7
desert-rat
City & State: Avondale AZ
The old (ww2 era) aircraft tube radios had a small motor/ generator for the tube plate voltage ( 150-300 vdc typically)
desert-rat is offline   Reply With Quote
Old 04-01-2022, 02:36 PM   #8
brethin
City & State: Owensboro, KY.
They way Video Card requirements are going I wouldn't be surprised to see a 24v or higher PSU introduced in the next year or so.
brethin is offline   Reply With Quote
Old 04-01-2022, 02:38 PM   #9
brethin
more power less connecters.
Old 04-01-2022, 02:39 PM   #10
brethin
It's the same reason battery yard tools went to 80v vrs 40v.
Old 04-01-2022, 06:03 PM   #11
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I've kind of wondered this a little as well..... I'd love to see the little kiddies playing inside their PC's when there's a motherboard full of exposed metal with 80v present!!
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 04-01-2022, 06:29 PM   #12
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
24V works great in my world. Pretty much *the* standard for industrial controls wiring (PLCs, automation, etc.).
Per OSHA (and other codes) Low voltage ends at 50V... which is why POE is considered low but 120V isn't. Which technically means the 90V on phone cords isn't low voltage either!
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 04-02-2022, 06:49 AM   #13
desert-rat
With the battery system on the new electric cars around 800v ,I can't wait until d I y ers with poor electrical skills start messing with them.
Old 04-03-2022, 07:49 AM   #14
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Hell's Front Porch
Line Voltage: 120/2/[email protected]
I'm a: Hardcore Geek
Unless there's ring current, then it's basically trickle-charge levels of current available.
Windows 10? Only if you like forced, buggy updates and 24/7 telemetry.
Samsung = Seagate = Seatrash = Trashgate
Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP.
SMR = Slow Magnetic Recording
Avoid SMR, buy CMR drives instead. SMR is easily a 15+ year step BACKWARDS in HDD speed.
Permanently Retired Systems:
TechGeek is offline   Reply With Quote
Old 04-03-2022, 01:03 PM   #15
Topcat
The Boss Stooge
Topcat's Avatar
~100v @ 20Hz will still sting you.
Those old magnetos from hand crank phones can be a lot of fun sometimes!
Old 04-03-2022, 04:56 PM   #16
ratdude747
Black Sheep
ratdude747's Avatar
OT: Took some digging, but I found a better smiley for you in this case:
Old 04-03-2022, 08:31 PM   #17
Topcat
The Boss Stooge
Topcat's Avatar
Added.
Good find, especially for this place!
Old 04-06-2022, 07:25 AM   #18
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
This is a good one
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
