Inogen One G3 portable oxygen concentrator Help!!!
    Posted here because this forum has the most viewers..Point me in the right direction PLEASE.
    I am looking for any guidance as to the repair of an "Inogen One G3 portable oxygen concentrator" My problem is how to reset the battery pack after replacing the LiIon battery cells. Battery pack shows full charge on pack indicator leds, unit does not recognize battery pack, Unit works with ac adaptor with no error codes.???
    Thanks to all for being__WAR_KITTENS____!
    Re: Inogen One G3 portable oxygen concentrator Help!!!
    Okay please post some pictures of of the battery pack you have
    What was the battery pack doing before you replaced the battery cells this information is very important to know I will explain later
    If possible can you please take pictures of the inside of the battery pack and the circuit board or boards if it has more than one
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Yes, please post all the photos you can as we will need to see it to properly help (and even then it may not be enough). Please post what you can and any details you can.
