Dell n5010 can be converted from graphic version to non graphic
    Re: Dell n5010 can be converted from graphic version to non graphic
    What is resonator capasitor
      Any one who succeed?
        i have tryed this and it works fine
          Didn't you get that fault like some have said like screen becoming white or clack after the bios?
          how did you do?
            how did you do?
            if you do it carefully, and slowly it will work if you forgot somthing like inductor
            or resonnator caps it will stack.
            my advise is : before start the conversion be sure it's discrete ati problem, confirm by 8 beeps gpu fault, if the laptop dos'nt give a beep code, press and hold Fn key and power it on, if still no beep code do a light reflow to gpu, if it display,start your conversion, ( follow the guide step by step carefully)else it can be bios problem or pch problem.
            good luck, friend
              good luck, friend
              noted....! Thank you very much for your help and support. I will try like you said..
                hi wont to try this method to disable ati chip,
                but before i have a question :
                the chip ATI need to remove it or i can leave it onboard?
                  can anybody tell me if i need to remove the ATI chip or not .
                    No need to remove chip
                    Im Back... sort of...
                      If I convert from discrete to UMA, is it needed to change the BIOS?
                        Very Use Full
                          Thanks Megaraider.
                            I tried this method but getting white screen any solution for it.
                                remove or change the oscillators caps near the crystal, the picture will be ok. you are used a bad caps.
                                  i changed caps as well as i removed caps but display is same.
                                  White Display
                                      White Display
                                      can you post a picture off your white picture ?
                                        Sir how many item exra add in board.from market for fully complete.
                                          Hi please find attached
