Hi guys
I got a beast of a ATX PSU here with a blown Standby section - Tagan TG700-U25
It takes a power surge at switch on to charge up the main electrolytics then goes to practically no current so I think the main section is probably OK
Problem with this one is the standby section has a discrete power FET which burnt some components on the PCB
Firstly does anyone have a schematic for this supply otherwise I doubt I have any chance of fixing it.
From what I can see the Standby supply provides 5Vsb and possibly the -12V supply rail (or at least the -12V comes of the same connector on the ATX pcb but I didn't trace it to see where it acually comes from). There doesn't appear to be a short on 5Vsb
I has occurred to me maybe I could use my bench PSU to provide 5Vsb and then see if the PSU would power up. Also it could be possible to squeeze a small 5V PSU inside the atx casing to effectively provide 5Vsb and 'bodge' it?
If i get it working I only wanted to use it in my own workshop on my soak test bench anyway, for motherboards and GPUs
