Hi! Hope you're fine! (:
So a friend gave me this unit which had faulty pushbuttons. Sadly I messed things a little up while doing the job.
Here's the schematic hosted:
https://elektrotanya.com/dbx_1066_sch.pdf/download.html
I managed to repair a vias connecting bottom and top with a bridge. After this sound is back on channel 1.
More saddly I managed to destroy channel 2 by an overload occured while testing (too much volume). Now channel 2 is dead and I'm left with channel 1 who seems to work fine.
As I am novice in repairing such kind of stuff and wanting to lurn as much as possible by the way I try to understand the schematic and make a "reverse engineering the signal path from the input. That I destroyed stuff is sad but if I see it as an opportunity to learn even more I will be very happy!
So I'm looking at that first stage and looking at my documentation I see a substractor opAmp configuration. So what I understand is while this a balanced signal that's the stage where te noise accumulated gets canceled out.
But also, isn't there a banpass filter?
In fact what I wish right now is beeing able to calculate theorical gain and expected output for a 1KHz 1Vp-p input. In order to understand what
I would share lot of pictures of my scope and schematics modification with measure points and my references for the formulas but I'm not sure where I should best host my images. Any suggestions?
Cheers
Any help greatly appreciated!
Cheers
