Need help to identify a component (diode?)
    Hello guys,
    can you please help my identify components with numbers 53 and 59? They could be a diodes?
    This component 53 is connected in parallel between source and drain of a P Channel A2179 Mosfet.
    I wonder what is their purpose here.
    Thank you!
    Re: Need help to identify a component (diode?)
    This might help you
    http://www.s-manuals.com/smd/53
    Zener Diodes
    https://cdn.badcaps-static.com/pdfs/...57602c93cc.pdf
    Google search—> SMD diode “53”
    Someone else would have to answer this question for you
    “ I wonder what is their purpose here. ”
    I hope this helps you
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      The thumb nail picture is too small, there seems to be other markings (above the 59) on the devices? Since there are 3 in parallel I would almost suspect they are capacitors?
      What is the board from? any numbers on the board? Can you tell how the circuit is used? is the mosfet just used as a switch?
        Thank you sam sam sam.
        R_J this is from Fujitsu H700 laptop board. I have no schematics, but I can guess that Mosfets are used for protection since thea are in close proximity of the batery. There is a current sensing resistor there.
          It looks like a Tantalum capacitor to me too.
          Follow me on YouTube
          Learn Electronics Repair
