Dell J728N 2700w UPS-Battery disconnected
    Hi .Can anyone help me about this UPS please.
    It wasn't any problem on it before customer said.He just left it on the side for couple of
    months.After they replaced batteries for following use.
    now it says" battery disconnected" alarm #199.
    Batteries voltage is 106v
    charge level level goes up.Thank you.
    Re: Dell J728N 2700w UPS-Battery disconnected
    Battery voltage in the menu is 60v 13% goes up.
      wait and see how high it goes .
        it has 8x12v batteries . best check voltage on each one
          Battery pack has 106v.Every battery have 13.24-13.27 volts
            check the fuses and see if there is a reset procedure
              When i start outputs in 3-5 sek. start " Alarm #28 DC link Over voltage"
                All fuses are ok.I've done reset of alarms and factory reset.
                  Does someone has schematic for this model or any similar please.Thank you.
                    Thank you Petehall347 for your answer.I've done it. Problem was broken way between
                    R17 and R18 because of moisture.
                      i guess it became a fuse .
                        NO broken path between them.Broken connection because of corrosion .From
                        this resistors reading battery voltage R17-R18 and R27-R28.
