Hp 15 5 blinks and 3 fast blinks
    Please has anyone encountered any problem with this hp pavilion series,
    Board IdAX1BMBAF0, It gives this caps lock blinks with no display.
    5 slow blinks and 3 fast blinks. According to hp troubleshoot they state that error code to "The embedded controller has timed out waiting for the BIOS"
    I have reprogrammed the bios but its still the same
    Re: Hp 15 5 blinks and 3 fast blinks
    no one has any info on this issue?
      Change Oscillator near ENE. . . . Problem will be solved.
        What is this "ENE" you speak of? I'm having same issue.
          It is probably SIO chip.
          Regards
          Steve
            I had the same issue ,resolved two days ago
            You have to check crystal (oscillator) near PCH
            It is a clock generator (frequency generator)for PCH vice versa
            Second check Vccsa coil near SD card slot there should
            Be above 0.94 voltage.
              Not sure what an SIO chip is. Well I tried to perform a BIOS reset before I got your message by holding Windows key and "B" and now the fans spins for half a second and the power button light goes off, so now I am not even getting a flashing caps lock. 2 steps backwards...
                stingerchamp, So even though board does not power on I checked Xtal with silly scope and I do have a 32KHz RTC signal. Not sure which coil by SD card slot you are referring to. I have the board out of the case just FYI
                  Still getting 5.3 blink code. Could the SPI IC be bad itself? I tried to flash the BIOS and nothing changed.
                    It started out with a bad battery (puffy cells)
                      I figured out what "SIO" means. "Super I/O" aka "EC" or "Embedded Controller" IC
                        Can a bad battery kill the SIO?
                          My board was dag35dmbad so in your case it may not be the vccsa coil issue
                          Vccsa coil is connected with CPU core supply
                          Anyhow
                          If bad battery then remove it and check
                          It is good you have 32khz clock available means rtc circuit is fine provided 3volt available at rtc battery
                          If your charging battery is faulty replace it and check
                          Software check:if 3volt available at cell, have you tried CMOS reset by pressing ctrl+v key while holding power button ,read hp page for details
                          Replace ram or use different ram slot and check
                          Do hard reset to remove any residue voltage in motherboard
                          If all fails time to work on motherboard
                            Anything can kill anything, but it's really unlikely. Batteries can't magically fail into producing more voltage than what they're charged to, and there are several layers of isolation between the SIO and the battery itself. If the SIO is dead, it's probably not because of anything that the battery did.
                              Cool, Will try things suggested.
                                Are using genuine charger with correct wattage?
                                  Yes. Using the original charger.
                                    Hello. Same issue here. Did you manage to fix it?
                                      Hello dear, I have the same issue. did you manage to fix it?
