EGO 56V electric lawnmower, blown 40A 250V fuse
    Good morning. I'm working on an EGO brand 56V electric lawnmower like this one.
    https://www.homedepot.com/p/EGO-21-i...02SP/206515944
    I found the 40A 250V ceramic fuse to be blown. I temporarily jumped it with a 35A blade fuse and it powered on and worked.
    The fuse in question is a Schurter SUT series slow-blow fuse with pigtails for through hole mounting. When I look up the SUT series of fuses, they only show a range of 12A-30A. I'm having trouble finding an appropriate fuse. I don't have the knowledge to find a suitable replacement on my own.
    Here is the data sheet for the SUT series of fuses.
    https://cdn.badcaps-static.com/pdfs/...21042e2a76.pdf
    I don't really care if the fuse has the same package as long as it works the same. I don't have the mower in front of me at the moment, but the PCB that the fuse was mounted to has pads for a smaller surface mount fuse if I could find one of the appropriate size. I'll measure the distance from pad to pad when I get back to the mower.
    In the time being, I would really appreciate it if any of you with a better understanding could help me out.
    Thanks guys.
    Re: EGO 56V electric lawnmower, blown 40A 250V fuse
    The only thing that Digikey has that is similar is this: https://www.digikey.ca/product-detai...785-ND/2518690
    However, this is a fast blow, not a slow blow...
    Or this:
    https://www.digikey.ca/product-detai...792-ND/2515916
    https://www.digikey.ca/product-detai...0801-ND/701068
    These are a slow blow.
    I'd probably change the fuse holder to accept blade fuses and take a bunch of those fuses of the last link.
      Can we see the circuit board that the fuse is soldered on to?
        if you can mount it, how about using a domestic circuit breaker??
        or use the fuses sold for car audio.
          I don't know if either of those would be a good idea.
          Looking at the product from the link in post #1, this appears to be battery operated (Li-ion) @ 56V. This means car fuses may not be a good idea, as the DC voltage is quite a bit higher and may arc-over badly in case of a quick-blow / disconnect event.
          Likewise, a house breaker is rated for AC current, so again, I'm not sure if disconnecting high-current DC voltage would do it any good.
          It's best to go with same rating and type of fuse. Of course, if you cannot find the same package / size of fuse but can otherwise match the current, voltage, and type of fuse, then going with a different package is okay - even if you run the fuse with thick wires / leads to get it connected properly.
            I found a Bussman 3AG glass fuse that should work. MDL-40. The data sheet only goes up to 30A. I'll have to mount the fuse a little differently as the replacements don't have any leads.
            https://cdn.badcaps-static.com/pdfs/...e500281c7a.pdf
            I've attached a pic of the board.
              the car audio fuses i'm talking about are big glass ones - they sometimes show up in other places like my old UPS.
              not regular blade fuses.
                Originally posted by CapLeaker View Post
                Thank for posting this I need something like this for a cooling fan for a machine at work
                I looked at what Little Fuse has in that type of fuses the lowest amperage fuse is 30 I need a 15 amps ones
                Originally posted by johnboy1313 View Post
                This is in response to what you posted above
                If it were me
                I would use this one and do away with the pcb board and fuse holder
                9 PC LCD Monitor
                6 LCD Flat Screen TV
                1 Dell Mother Board
                15 Computer Power Supply
                All of these had CAPs POOF
                  If it were me
                  you're welcome!
                    Thanks for the help guys I'll report back once it's working again
                      You have room on the PCB you can use this one:
                      https://www.homedepot.com/p/Cooper-B...R-40/100170316
                      Just wrap and solder solid wire to each eand.
                        This maybe useful for me as well, I have the same mower, but it haven't fail yet.
                        Why this fuse may have failed in the first place?
                          a good question.
                            He said he was mowing wet, tall grass when it quit working.
                              well if the extra load took out the fuse, it didnt have much headspace!!
                                It would seem that way.
                                  Thanks CapLeaker. I went with the first link after the "40A 250V" fuses I ordered on eBay turned out to be 40A 32V fuses. It's working again.
                                    A1! I like seeing things work again!
