Hi there,
My latest electronics project involves bringing back to live a 50 inch Panasonic plasma TV. When I first acquired it, I was told the power supply board was bad but the previous owners did not get this fixed as they couldn't afford it.
The model of this power supply board is N0AE6JK00006 and unfortunately I do not have a schematic.
Anyways, I checked the fuse which was turned out to have blown. I replaced the fuse but this blew as soon as I plugged it into the wall. At this point, I knew there was a short someone on the board and after some detective work with a multimeter, I traced the short to two power mosfets Q207 and Q208. They were shorting across all three legs no matter how I read them on the meter.
Thinking I found the cause, I ordered the exact replacement mosfets, soldered the pair on and replaced the fuse. About two seconds after I switched it on, the fuse blew again! I immediately checked the mosfets and to my worse nightmare... they were blown, in mere two seconds of receiving power!!!
I removed the board from the TV and checked everything I can on the hot side with my multimeter. All the resistors, diodes and the bridge were fine. I even lifted one leg from the board to check. I do not have a capacitor tester yet to check the capacitors however I did test them for dead shorts of which there were none.
Aside from what I think could be faulty capacitors, I'm worried that the mosfet gate drivers might be damaged. The gate connects to a series of SMD resistors before a small transformer before some more resistors and finally to an IC chip which I believe (not certain) is the gate driver IC. The chip has the following text printed on it...
25600
a351
19M
I am looking for any helpful hints which will help me repair the board and id I do need to replace the IC, where could I source this?
I have attached some pictures of the circuit board. The first one is the component side, an exact board on a parts website. The second picture is the underside of the board beneath the mosfets showing the area nearby and the what I think is the mosfet driver IC. The mosfets themself has been pulled from the board.
Thanks in advanced.
Top side
http://assets.shopjimmy.com/media/ca...0006-top_1.jpg
Bottom side
http://img855.*************/img855/5513/amth.jpg
25600
a351
19M
Thanks in advanced.
Top side
Bottom side
