got this TV for 10 bux because it doesnt turn on. no standby light, no standby voltage.
i noticed that one of the big ceramic fuses tests as open.
so i replaced it with another ceramic fuse from a dead PC power supply i had lying around. when i plugged in the TV, not even a second later i heard a loud pop and thought i saw spark even at the fuse i just replaced. also it looked like the fuse got cracked or damaged in some way.
i assumed the TV had blown the fuse just like it blew the one before it but when i checked with my meter, the fuse is still OK!
so what popped then?
the original fuse says T3.15AH250V but the one i replaced with just says 250V on it. what does the 3.15AH mean? is it possible i used the wrong fuse and blew something else up?
also i notice now that it takes forever for the main filter cap on the right to discharge itself. the one on the left discharges in a couple minutes but the one on the right takes a really long time! i didnt really test this before changing the fuse though so im not sure. but i think i remember it draining pretty fast because i was able to change the fuse without waiting forever.
