Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    tv
    FIRMA: Vivax
    MODEL:Lcd tv-3250
    MODEL DODATNO: Tv 3250SM1212D306
    MAINBOARD:Sinho 090-DM306K-00
    PANEL:V315H-L02 Rec.C1
    Power:AY130P-4HF12
    Memorija-W25Q64 Plizz firmware,dump
      Looking for:
      Mark: Silver
      Model: IP-LE32/495523
      Chassis (main board, components): TP.MS3663S.PB818
      LCD Screen/Panel (if exist): D32-M30 32JP2006024000106701
        Re: I-JOY idi22spb 05 V2
        Hi someone says the instructions for entering service menu in HK-7050-CI-V4.1-B ?
          sony kdl-55ex710 eeprom dump please
            Require Dump for-:
            JVC LT48C570 or any other brand that may do.
            Main board: T.MS3463S.711
            LCD Screen: LSC480 HN08-8
            No Spi chip in UF1..... uses larger chip underneath in position U3.
            Can anyone help? Thanks, Dave.
              good evening, I am looking for dump emmc LG 42lb650v-zn, main eax65384004 (1.5) ebt62800437, LC420DUH panel, I have the rt809h programmer, thanks
                Sony kdl-55ex710
                Main board: 1-881-636-21
                LCD Screen: lty550hq2
                eeprom dump help!
                  Veuillez mentionner le nom de la marque par laquelle l'original a été remplacé au profit de tous les membres Merci beaucoup pour ce beau travail
                  MOD EDIT: Please mention the name of the brand by which the original has been replaced for the benefit of all members Thank you very much for a great job
                    thank you
                    Last edited by SMDFlea; 06-29-2021, 09:27 AM. Reason: https://translate.google.com
                      Westinghouse VR-4625 EEprom Dump
                      Hi, Everyone, I'm in need of the EEprom dump for this model
                      The Model and board numbers are as follows:
                      Westinghouse
                      VR-4625
                      TW-64801-5046C
                      T.RSC8.10A 11153
                        Sorry the full parts number on the bottom side of the board is
                        1B1H1754
                        LTA460HN1-W
                          loking for dump sumsung UE46F5300
                          thank you in advance
                            Anyone a member of DTForuM ?
                            Looking for a .bin for a 19" Haier the one posted in this thread is for a different mainboard and will not work.
                            Here is a link to the file in post #2 if someone has access. Thanks.
                            (I registered then found out I needed 50 posts to download so I tried...)
                            Code:
                            https://www.dtforum.info/index.php?topic=160545.msg1011118749#msg1011118749
                              hi, i need software for 17mb97 - ves400unds-2d-n11-finlux-40inc
                                For programmer
                                  Does anyone have usb firmware for any of these:
                                  SEIKI SE42FYT
                                  SEIKI SE40FYP1T
                                  Element ELSFWC321
                                  Westinghouse WD50FBE1001
                                  Westinghouse WD40FW2610
                                    need eeprom haier 55e3500b
                                    hi,im looking for the eeprom for a haier 55e3500b
                                      Hi guys!
                                      Does anyone have the dump for:
                                      Model: Emerson LF402EM6F
                                      MB: BA4GU5G0201 - 4
                                      PSU: BA4G25F0102 - 2
                                      PANEL: 1EM439757
                                      Thanks in advance!
                                        Originally posted by 6BW6 View Post
                                        Require Dump for-:
                                        Try from Sharp dump
                                          Looking for dump for:
                                          Emerson LF320EM4A ME8,ME9 IC3006
                                          Main A4AFSMMA-001
                                          Panel No. U44FEXT
