Sharp Aquos LC-60LE600U no power period
    Re: Sharp Aquos LC-60LE600U no power period
    You think the key control board? there must be a diagram for checking somewhere
      Pin 22 ERROR = 0.95V
      The problem right now is that we do not know what the value of this Voltahe should be for the main board to think that it is normal, this error signal may be keeping the TV from sending the control signals, I cannot find much info form most of the Sharp TV service manual to tell me what the normal condition should be.
      Need to do more research or if someone has working board can take the reading for us to verify.
        I did some searching in BC, it looks like the ERROR should be high. Looking through the PDF in the link, it looks to be that the ERROR pin is for the Backlight Error.
        https://www.badcaps.net/forum/showth...rp%22+%22pd%22
        https://www.badcaps.net/forum/showpo...92&postcount=1
          Thanks bud I will try to check the key button controller, and are there any key components on the main board I should check since there is an issue? How are you making out with the LC-70LE757U? if you need and readings etc. we could take mine off the mount to help you out- let me know
            Another thread to follow:
            https://www.badcaps.net/forum/showth...982#post722982
              I think the reset procedure is to hold down input and vol- at the same time you plug it in.
                I'm going to go through it again I think I tried all that- how did you make out on yours with the LED issue?
                  Having same issue no power at pin 1-2 any ever resolved this issue. My house was struck by lighting
                    Hi All, I have a LC-60LE600U with blown fuse. I did quick check and looks like its rectifier is fried. Hence I am looking for actual part numbers for the Bridge rectifier, the Q7801 and R7816. Does anyone have schematics?
                    Thanks in advance for your help!!
                      Just checked even the variastor is blown but its number is visible so I can get a replacement for it.
                        There should be part number printed on the Bridge and the Q7801 (PFC MOSFET).
                        If that PFC MOSFET is blown, more likely the components connected to the Gate and the PFC IC are likely to be damaged also.
                        You should attach the pictures of the board?
                        What is the P/N of the power supply board?
                        Sharp RUNTKB057WJQZ (DPS-168JP A)???
                        MOV Z7001 is blown? 150V rating MOV with about the same Dia, will be fine.
                        What is the history of the TV? Hit by power surge?
                        Pictures provided by shopjimmy.
                          Thanks for the superfast response BUDM. Do you know the value of R7816? Looks like owner replaced (or got it replaced) the resistor. Currently it has a 6.8 ohm resistor. Not sure if thats the right value.
                          Sharp RUNTKB057WJQZ (DPS-168JP A)??? yes its DPS-168JP A
                          What is the history of the TV? Hit by power surge? I got it from Craigslist hence no information on history.
                          Pictures provided by shopjimmy.[/QUOTE]
                            R7816 is the current sensing resistor connected to the Source pin of the PFC MOSFET, when MOSFET shorted out it will blow that Source resistor, it is 0.56 Ohm Flame proof type resistor, you can use MOX (Metal Oxide) power resistor.
                              Thank you once again Budm!
                                I was dignosing the TV further and found on the board KF905FM04 and found the diode 9601 is bad. Does anyone know whats the value of this diode?
                                  Budm, what is the wattage of this resistor? 1W or 2W?
                                    It looks to be 2W but you should measure the dimension to get the correct size.
                                      thx again Budm
                                        I was diagnosing the TV further and found on the board KF905FM04 and found the diode 9601 is bad. Does anyone know whats the value of this diode?
                                        I have attached the picture of the part.
                                        Thanks in advance!
                                          Thanks in advance!
                                          What is this board you are referring to?
                                          Can you zoom out so we can see what connector it is connected too? It looks to be protection diode.
