Sharp Aquos LC-60LE600U no power period
    Re: Sharp Aquos LC-60LE600U no power period
    Originally posted by Adubey View Post
    I have attached the picture of the part.
    Thanks in advance!
    Added one more pic
      So what is the pin number of that PD connector the diode is connected to? Once you know that then you can look at the PD pin name of the power supply connector to see what is fed to that pin.
        thx Budm, I found its 3.3V zener diode, 200mW - Panasonic DZ2J03300L
          I still like to know why they put 3.3V Zener on one of the connector PD pin, the Zener may have been damaged due to over Voltage. You need to find out what PD pin is connected to that Zener to be able to verify that you are not having over Voltage condition.
          Make sure to count the pin correctly since you have odd and even column pin arrangement.
          BTW, can I see the pictures of the whole backside of the TV showing how all the boards are connected together?
            its connected between PSON (pin 14) and gnd
              So did you remove that shorted out diode and then test to verify that PD pin on the main board where the Cathode of the diode is connected to goes to PSON pin 14 of PD connector on the power supply board?
              I would expect 5V Zener for clamping the PSON pin, not 3.3V.
                Hi.
                if real this measure
                Pin 24 STB = 0.58 V.
                no it's normal, you should have a voltage between 5v and 3.3V.
                as you say that Pin 14 PS_ON = 2.07V.
                hypothesis?
                isn't it that you have a faulty stand by circuit?
                  Originally posted by videocentro View Post
                  Hi.
                  hypothesis?
                  https://www.badcaps.net/forum/attach...2&d=1486005691
                  STB Voltage as reported by original OP is BL-ON control signal.
                  STB pin for this Sharp TV is not Standby POWER SUPPLY output, it is BL-ON pin that gets the command signal from main board, see the pins description.
                  BU5V is the Standby power supply pin.
                    Budm, I referred to the following document that gives the circuit diagram. Check it on page number 11.
                      Budm, heres the picture of the whole backside of the TV showing all boards connected together.
                      I replaced the defective bridge rectifier, blown fuse, .56 ohm resistor and the zener diode. After shorting PD 14 and 15, I can see that the pf capacitors are getting the proper voltage of 400V. Connecting all of the boards together when I connect to power, the white LED turns on, backlight turns on momentarily before turning back off. atleast 1 step forward
                        hi i have the same board and the ic Q7801 is blown out with the cap next to it how do i find a replacement for it?
                        Thanks in advance
                          Thanks in advance
                          You can desolder it and look at its value.
                            So at this point what are the Voltages on the PD pin of the power supply board when TV is OFF and when TV is turned on?
                            Make sure to put down pin name and follow by the reading for each pin so we can easily see what it does or does not have.
                            Also, are you getting the LED blinking code?
