Corsair GS800 Power Supply Problem
    Re: Corsair GS800 Power Supply Problem
    Originally posted by R_J View Post
    where do you see voltages on the secondary?
    He is still getting like 0.1v or something, I don't think that would be there with an open gate drive resistor.
      R116 is the source resistor for Q11, I wanted to see if it was open or not, turns out it is good.
        I also see Q7 has an insulating kit and Q11 does not, has it been changed to an insulated mosfet? I hope it's drain is not connected to the heatsink. or is Q11 an original and Q7 been replaced with something else?
          I just checked the pictures again and you are correct on the resistor, I also did notice that Q7 and Q11 are different, one is a full pack the other isn’t. There is insulating hardware on Q7, but either it is bad, or Q7 is bad. Do Q7 and Q11 have the same part number?
            If D13 cathode is 377v and D19 cathode is 377v then Q7 is either turned on or shorted.
            D13 cathode connects to Q7 Drain
            D19 cathode connects to Q7 Source
            Q11 original if I remember correctly. Q7 was sourced from another PS
            Removed Q7 and it is not shorted. Yes Q7 does have insulating mounting hardware. I will run an independent bench test on this and see if it is good.
            It does appear .19 volts is making it through the transformer to the secondary side for the 12v rail.
            Q7:
            Q11:
              I would also check the resistance of the primary of the transformer, If you have +377v on D19 cathode, you should also have that voltage on D13 anode, and you do not.
                Feedback winding continuity.
                Primary open.
                Neg side of primary winding to feedback is 11 megaohm.
                  Primary open.
                  That would do it. open primary
                    When the original Q7 shorted it took the primary winding with it? Unfortunately, I don't think these transformers can be sourced reasonably cheap.
                    Here is the suspect as oriented from the board bottom-view:
                      Have a close look at the wires that connect to the pins, sometimes it can break right where it connects to the pin.
                        Solder joints look good. Primary winding is actually two wires whereas the feedback is only one wire.
                        Curious. If I am getting .19 on the secondary side that suggests the primary winding broke early in the wind?
                        Is it possible to fix this transformer? If i could find the opening a small bead of solder would be an acceptable fix? It appears the outside is glued together:
                          Check the primary winding to those pins that are cut off, I suspect there might be a thermal fuse in the primary. I marked where it might be, but it could also be between the other cutoff pin. check the resistance between those pins, the transformer might be fixable.
                          You posted a picture of the secondary side, But post a similar picture of the PRIMARY side. I might be able to tell if there is an imbeded fuse
                            Feedback Yellow: .78
                            Primary Green: 1
                            Thermal Fuse Red: open
                            Might be here Blue: 1
                            Primary Side:
                              an open primary would do it alright. As RJ already said, check the thermal fuse in the primary, if it has one.
                                BINGO! Pin 5 (per post 33) has two wires and one is cracked/split. Looks like QC issue. The wire was not long enough during the manufacturing process and came up short it appears...so just add a glob of solder? Friday Build. I never would have found that without you guys. OH CANADA...!
                                  Good find, BUT is the power supply going to work? lets hope so.
                                    Stop now while we are ahead...? Will post results in a few hours....
                                    Fixed break and we now have continuity across the primary winding as originally predicted.
                                      very good find! keep my fingers crossed that it works after you reassembled it.
                                        Preliminarily it works!!!!!!!
                                        Tremendous ty
                                        12.2v
                                        5.0v
                                        3.3
                                          awesome!
