So this is not a right expensive unit but i'd like to fix it if i can. The unit will shut itself off approximately 5 seconds after it turns on. I re-soldered a cap that had a cold solder joint. It seemed to work for a while but now it's back to turning off again. Im thinking i should have swapped the cap right out with a new one now. I find the led display to be dim also but i dont know if that is related to this issue. If anyone had a similar experience with this unit or a similar one, let me know what you did to resolve the issue. Thanks.
Service manual: https://servlib.com/sony/audio/mhc-e...c-ec919ip.html
