Onkyo TX-NR616, constantly clicking, no display, no light/led
    Re: Onkyo TX-NR616, constantly clicking, no display, no light/led
    This is what i get when i check the firmware
    any help appreciated please
    I have tried to do update by using the ethernet cable
    When i try to do them individually using the menu
    it gives the following error
    error!! 5-82
    on vsp and vmpu
    not tried by usb
    I have a a uart cable and a USB CH341A chip programmer
    Many Thanks all in advance
    Please help
      Hey all
        Originally posted by budwich View Post
        try using a USB stick to update as opposed to a network connection.
        Hi
        All
        I have tried to update by USB and still get the same error
        5-82 on vsp and vmpu
        Please can someone send me the firmware so that I can program this myself or upload it
        alternatively can I use the UART cable
        Please can someone reply and assist me, I will be really grateful and appreciate it so much
        Many Thanks
        Kind Regards
          How did you try and update it via usb if you don't have the firmware? Download it from Oink-yo
            Originally posted by R_J View Post
            How did you try and update it via usb if you don't have the firmware? Download it from Oink-E-yo
            i downloaded the official firmware and put it on a USB drive but get an error
            as mentioned
            i read that i can flash the nor chip (q8040) using a chip programmer but i need a firmware dump from another board
            I was also reading that this might be able to be fixed using UART but not sure how
            please i need lots of help
            thanks in advance
              I take it you unzipped the 3 files and the 1 directory to the root of a clean FAT32 formatted usb stick.
              Do you get:
              Select the USB input source.
              “Now Initializing...” appears on the AV receiver’s
              display and then the name of the USB device is
              displayed. It takes 20 to 30 seconds to recognize the
              USB device.
                Do you get:
                “Now Initializing...” appears on the AV receiver's
                USB device.
                yes i done exactly that but it gives me error 5-82 on vsp and vmpu
                have you used uart on these onkyo amps
                  No I have not.
                    No I have not.
                    ok thanks
                    have you ever seen this error i am having
                    please can you help
                      you might want to check / ensure that those processor boards have the proper electrical conditions (voltage / ground) to allow for proper operation before going down the path of trying to "manually write" the firmware. It is a strong possibility that there is a issue at the board level.
                        I have not seen this error, if you look it up on the internet you will see others that have had it. It says it is a time out error.
                          Can you help with this Please.
                          I have one screw in the hdmi port to chassis
                          What voltge do I check and where do I check .
                            I saw that but I've tried by usb as well so not sure why it is timing out . what can cause this
                              Have you checked the update procedure that tells you to configure the amp in a certain way before updating the firmware?
                                Yes I did but can't see anything on the tv. Can't get the osd to show. So no way me to turn off things. I have done the rest key combination so I assume it's ok
                                If you know how to then please post
                                  I have been thinking it might be a voltage problem but i cant get to the regulators as they are on the bottom of the board.
                                  can I do any tests from the top or can i flip the board over with something underneath and test and
                                  in order to do this do all the cables need to be attached
                                  Thanks so much
                                  please can someone help who has worked on these boards
                                  can someone tell me which regulators please
                                  thanks so much
                                    interesting pdf,
                                    so are you just connecting the power cord??
                                    i cant help thinking this thing tries to download something over ethernet!
                                    The firmware update should take 15 to 40 minutes
                                    really??? not from a usb it shouldnt!!
                                      interesting pdf,
                                      I cant get it to do any firmware update
                                      I am leaning towards a voltage problem where the chips are not being powered
                                      Can anyone help with this please
                                      thanks
                                        you probably need to look for the source of 3.3v or equivalent that is usually used for logic powering. You don't actually need the actual source (regulator or otherwise) at this point, just check test points on the various boards that show access or provide access to that type of powering so that you can check if it is there or not.
                                          I have tested voltages on the following coils
                                          L8932 - 1.3V
                                          L8942 - 1.8V
                                          L8952 - 3.3V
                                          L8962 - 5.2V
