Ati R9 290X - work ok without load
    Hello.
    Have this Asus AMD R9 290X that works normal on full hd/video. office,.../ but when u try put load on, it freeze the pc.
    Weird thing is i can run furmark on 640x390 with 8xMSAA to full load and heat. if i try just little higher resolution, it freeze.
    GPU could not get higher because BAD GPU, or i have some bad GPU power phase
    Re: Ati R9 290X - work ok without load
    Or faulty RAM?
    Follow me on YouTube
    Learn Electronics Repair
      u mean that with low resolution i did not trigger faulty ram?
      but how to detect which ram ic is faulty? is there some test for GPU rams ?
        Yeah that's the sort of possibility I had in mind.
        I am sure there is test software available if you google for it. Searching 'GPU ram test' finds quite a few hits for me, so have a look.
        Whether test software will tell you anything useful is a good question - but I would certainly give it a go
