Hi, can anyone create Patch for my Lenovo ThinkPad T460. The BIOS file attached is 100% working fine, only I want to get rid of the Password. Thanks in advance
Thank you so very much... I re-programmed ther Patch file on the BIOS, re-soldered the chip. But now it give 5 beeps pauses & then again 5 beeps & NO Display at all. Maybe something wrong with the Patch. Please re-try if you can. Thanks anyways
Thanks Mazorca:::: Attached is the 100% Patch file.. I have tested it & it works & give a Hardware ID.. I had to pay $$$ for this service but I like to help others if in need. Thanks for your file & you can see what they did & what wrong did you do that your file did not work. Thanks
hi friend plz what is the valid key for your file its asking for a valid key plz can you post it
STEP 3: Press ENTER/F1/esc. to enter BIOS settings
STEP 4: Enter 1234 PRESS ENTER
when asked for Password
STEP 5: Press ENTER when it shows Hardware ID
STEP 6: Press space bar 2 Time when asked 1 by 1
STEP 7: Turn off machine
STEP 8: now again open laptop and write your original BIOS file which you have post here ( t460.ZIP )
STEP 9: Reset BIOS settings to factory default
Thank you very much, friend.
Please advise how do I flash the file given by youin STEP 1? Is there a guide here, or can I simply use a USB flash disk with Freedos and a flash program like Winflash or something?
I just don't know how to flash this patched bios file now. I've been searching the internet including this website for many hours since yesterday. I must be missing something very simple?
