F556UQ-DM737T BIOS help needed =)
    Hello!
    I have a ASUS F556U which I suspect has a bad bios.
    When I plug in charger the device turns on by itself with 100% fan speed but no picture. When I hold down power button it shuts off, when I release power button it turns on automatically.
    I did read the BIOS (dump file: https://easyupload.io/du0nuw) if anybody could please take a look at it or help me with a completely new bin-file!
    Any help is huuuugely appreciated! =)
    Many thanks!
    dump: https://easyupload.io/du0nuw
    Re: F556UQ-DM737T BIOS help needed =)
    I tried with a random dump from the internet, and the machine then started to ASUS logo. But it does not work 100%
    But it's 100% a bad BIOS.
      Try this file and report if successful or not.
        Thanks, the machine does boot into BIOS with that file but there is no serial number and whenever I have a USB plugged in it won't boot into BIOS/Boot menu, ASUS logo shows then it shuts down :-(
          try ... if it doesn't work, post clear pictures with the white or green stickers on the motherboard.
            Unfortunely same symtoms.
            No SN in BIOS and when I try to access BIOS with USB connected it will shut off/not access BIOS
            Here are some pictures of board:
            https://easyupload.io/hvhuhd
            https://easyupload.io/f9dv9a
            https://easyupload.io/id8zpr
              Sorry! It will boot with the original beaten up charger but not with this ''new original'' one.
              Still no SN in BIOS though, could this potentially be fixed? =)
              BIG THANKS for the working BIOS!
                Try this bios.
                  Originally posted by SMDFlea View Post
                  Try this bios.
                  THANKS! =)
                  SN is now visible aswell! =)
