Microsoft Surface Pro 3 UEFI password
    Re: Microsoft Surface Pro 3 UEFI password
    It worked!
    Thank you very much!
      Hi to all, i write to ask help.
      As many other users i've bought a SP3 (i5 4300u+256gb ssd) on ebay without being informed of the UEFI pw....
      I've read the first pages of this thread but i'm stuck with FPTW64
      i have downloaded it from win-raid forum as said initially (mine is v15.40 r1 from this month) but when i try to dump to file
      Code:
      FPTW64.exe -D SP3
      i get two errors:
      Error 39: PCH is not supported.
      Error 620: Unknown hardware platform.
      FPT Operation Failed.
      Please Help me! i have always such this bad luck every time i have to face a sw problem....
        sorry for the dumbness... i've downloaded the right version(v9.5 r6) but no luck here... now as output i have:
        Code:
        >fptw64 -D SP3
        Intel (R) Flash Programming Tool. Version: 9.5.40.1868
        Copyright (c) 2007 - 2014, Intel Corporation. All rights reserved.
        Platform: Intel(R) Premimum Express Chipset
        Reading HSFSTS register... Flash Descriptor: Valid
          --- Flash Devices Found ---
          W25Q128BV  ID:0xEF4018  Size: 16384KB (131072Kb)
        Error 26: The host CPU does not have read access to the target flash area. To enable read access for this operation you must modify the descriptor settings to give host access to this region.
          i've finally found my real dumbness!
          i was launching the wrong command (without the -bios parameter)
          finally i have the bios.bin file!!
          please someone can extract the bios pw from there for me?
          alternatively can you explain how to retrieve it from the file(i know that is hex)? would be very helpful also for other users that stumble upon this thread!
          thank you!
            @RaKesh9
            password = client4tg3
              Originally posted by AAAC View Post
              @RaKesh9
              OMG THANK YOU!! IT WORKS!! I LOVE YOU!
              i was wandering to buy another one or two SP3 for my mother and my sister from the same seller(thus probably they will be pw protected too)
              i will come back to ask again if it is possible.
              thank you so much again!
              P.S why cannot be fully explained the last part of this process(find hex string-decrypt)? it involves breaking some rules of the forum? or commercial rule about manifacturer?
              thank you again and anyway!
                Use the search option, it has been explained before.
                  Hello, hoping that everyone is in good health and that all this is over.
                  Please help me with the password surface pro 3
                  Thank you so much
                    @DennisCH
                    password = f*****u*****c*****k*****y*****o*****u
                    Just put together the characters without the "*", that's the password.
                      ohhh
                      what password
                      Thank you so much
                        Hello everybody I'm a newbie here. Nice to meet you!
                        I recently bought a second-hand Surface Pro 3 which unfortunately has BIOS/UEFI locked with an unknown password. I didn't know this until the latest Windows Update failed, and I could not go into BIOS/UEFI to disable Secured Boot for recovery...
                        I manage to fully recover it from factory image, but would also like to update the TPM firmware to latest version for security sake. Secured Boot needs to be disabled to do it - could not proceed without the BIOS password
                        Have followed the steps to dump my BIOS as attached. Please help to decode the password. Thanks heaps in advance!
                          @zurg
                          password = v1nd3z
                            hello!
                            sorry, don´t know english well.
                            I have UEFI password for Surface Laptop 2 (not pro 3, Iknow).
                            May be is a chance to find the password? I will prey for you.
                              I also clear password please check this file.
                                @zurg
                                password = v1nd3z
                                Works like a charm! Thanks heaps AAAC
                                BTW, disabling Secured Boot would cause SP3 to boot with a bright red background, quite scary...
                                  Greetings,
                                  Standard situation, I bought a second-hand Surface pro 3 and it turned out that there is a BIOS password
                                  I will be grateful for your help in reading the password from the .bin file
                                    Originally posted by maxulus View Post
                                    Greetings,
                                    Password: bild
                                    b - bravo ( lowercase )
                                    i - india ( lowercase )
                                    l - lima ( lowercase )
                                    d - delta ( lowercase )
                                    Type the password and press <Enter>.
                                      Originally posted by onizzbox View Post
                                      Password: bild
                                      Thank YOU Very Very Very MUCH onizzbox. It works!
                                        Open your dump with Hxd or other Hexadecimal program
                                        Locate area with
                                        texte AMITSESetup or Hex 41 4d 49 54 53 45 53 65 74 75 70.
                                        Take the hex values in the red area (two passwords can be stored).
                                        Put the hex values in excel decoder.
                                          hello guys. I also have a surface pro 3 that is uefi locked because I forgot the password and I've been looking for a long time how to reset my uefi password and i found this site. I don't know much about computers and tried looking at winraid but honestly I don't understand it, and don't know which link to download. Anyone here can help me? Thank you so much
