Sony Vaio PCG-71213M bios dump plz
    Re: Sony Vaio PCG-71213M bios dump plz
    merci khoya je vais esseyé, en tous cas tu es de casa et moi de oujda, on peut faire des rechange de bios ou n'importe quoi, je suis technicien en informatique et je pense que c'est ton domaine aussi .
      même chose khoya, mais j'ai réparer le problème j'ai changé une parti du fichier.bin qui contiens le mot de passe, merci beaucoup pour votre aide .
        English please so we can flow the posts
          [QUOTE=cyberhack;678047]English please so we can follow the posts that would be helpful.
            [QUOTE=cyberhack;678235]
            I have say that this laptop it coming to me for some days with display and working good but the problem is after some
            minutes stoped -ie is overheating and shutting down-
            the heatsink was blocked with lint.
            naturaly for always i take a copy for the bios to all the laptop coming with problem to me
            and he wanted that we can helping us -exchange bios....idee because we are from morroco and not far .......
              Ok thank you
                english only. I will remove all non-english posts.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                  Re: Sony Vaio PCG-71211M bios dump plz
                  bios dump
                    Hi , i have the same sony vaio PCG-71213M (vpceb4j1e).which utility did you use to update your bios with the attached file ridamouh159 has sent you?I think i have a corrupted bios and i really need to reinstall my bios
                      Hello sommek, you have to remove the bios chip from the board and reprogram it using an external programmer.
                        Originally posted by SanWilliams View Post
                        espero que te sirva saludos
                        Thank you.
                        This is what i need too
                        Regards
                          Bjr everyone.
                          Here is my sony vaio pcg-71211 whose card was hs i bought another motherboard pcg-71213, the problem now is that my sony will only start if the battery is lodged and the charger is stuck.
                          It does not start with the charger alone or with the battery alone.j wanted to flash the bios but I do not find the flash software under dos thank you for your help
                            thank you
                              It works with sony vaio PCG-71213M[ VPCEB3E1E] thank you
                                Thank you.
                                  Assalamun Aleykum. Thanks you and all the developer of this site.I am very helped by this site.
                                    sony vaio PCG-71211M VPCEB1Z0E mbx-224 M961 MP MB RVE1.1 Bios + EC
                                      Ok thank you
                                        Originally posted by mc1255 View Post
                                        Bjr everyone.
                                        Regarding the same problem, for a Samsung laptop, I needed to change a capacitor behind the microprocessor. If I remember correctly, the latop would only start if I removed the charger and it would only work on battery.
                                          Re: sony vaio PCG-71211M VPCEB1Z0E mbx-224 M961 MP MB RVE1.1 Bios + EC
                                          Tnx tested ec bios ok
