I need help finding this capacitor for a G.E. washer. 2 of them were on the circuit board attached to the motor. They are 3-pin caps, which is making it very difficult to find. Here are some pics of the cap and the motor tag. Thanks!
Need help finding this capacitor.
Re: Need help finding this capacitor.
Originally posted by stj View Postyou can use a 2pin 10mm snap-in type cap
but you need to fix the board and probably glue the caps down because you ripped the plating out
Originally posted by apache23 View PostSo any idea what the 3rd pin is for? Besides confusing the hell outta people like me as far as finding replacements. Not to mention I thought there were only 2 pins on it as I was removing it, so I messed up the board trying to get them off.
But as stj pointed out, you ripped out the through-plating from the mounting holes, breaking or damaging the connection from the top to the bottom of the PC board. If that through-plating is necessary for the filtering of those capacitors you will have to find a way to restore the connection.PeteS in CA
