I see this value varies within several 3300uf caps. Do you want that number low as possible? It's very high on polymer caps.
Do I want Ripple Current high or low?
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Tags: None
Re: Do I want Ripple Current high or low?
Originally posted by ChaosLegionnaire View Postfor capacitors, it refers to the maximum ripple current handling capacity before the capacitor goes kaput really fast. therefore, the higher the ripple current handling capacity rating, the better. there is no limit. aim for the sky. hope that clarifies it.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
Well, a MB has DC-DC converters on it, basically DC input power supplies. So impedance and ripple current ratings for the input and output capacitors matter.
When you're talking about the decoupling capacitor networks for a processor, those can have current transients in the tens of amps at rates in the 100s of amps-per-microsecond. Narrowly speaking the electrolytic or polymer capacitors in the decoupling network need to be low impedance - low ESR and low ESL. But capacitors with low impedance generally have high ripple current ratings.Last edited by PeteS in CA; 09-30-2020, 06:32 PM.PeteS in CA
3300uF @ 10 V=Are you recapping an Asus socket 462 motherboard? (CPU runs off of +5V rail on Asus socket 462 motherboards) Or an early-one? (From the T-bird era)ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
Originally posted by RJARRRPCGP View Post3300uF @ 10 V=Are you recapping an Asus socket 462 motherboard? (CPU runs off of +5V rail on Asus socket 462 motherboards) Or an early-one? (From the T-bird era)Last edited by jayjr1105; 10-01-2020, 06:46 AM.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
Originally posted by bestsystem View Postsome of them are rated at 100KHz and some are 120Hz, i don't know why they are not measured at the same frequency?
Modern low impedance and ultra-low impedance parts will be rated at 100KHz because the anticipated usage is power supply and DC-DC converter output capacitors. Switch frequencies vary, of course, but the datasheets typically have a graph that gives an idea of how a part's impedance varies with frequency.
120Hz rated parts tend to be general purpose or designed for bulk input capacitance for a power supply.PeteS in CA
