DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Hi everyone.
    i have this laptop.
    this model is amd ryzen cpu.
    i want to this bios and saw this thread.
    https://www.badcaps.net/forum/showth...light=LA-F121P
    write bios but not clear bios password.
    i used unlock dell bios seller solution.
    but not clear it.
    if you know unlock this bios,please teach me.
    i attach my bios.
    thanks.
    Re: DELL Inspiron 15-5575 CAL51 LA-F121P Unlock BIOS
    Originally posted by Sato View Post
    Hi everyone.
    i have this laptop.
    but not clear it.
    i attach my bios.
    thanks.
    Password inside ENE.. kbc
      Seems like this model uses System Disable 16-hex code.
        Thanks reply.
        oh inside password in kbc...
        I see 16hex code.
        gen code enter bios but not clean.
        (Change all menu but not password clear)
        show locked setup.can not use gen code.
          @Sato
          You just have to modify the instructions, CTRL-ENTER-ENTER (instead of just ENTER) as in Latitude and similar models.
          Type: 8-digit password + (CTRL-ENTER-ENTER)
            enter the 16hex 8digit code.
            admin password is not clear.
              enter password again for old password, and leave new password empty ( just press enter )
                Hi
                Enter password 8digit password.
                show password is incorrect.
                  Thanks AAAC.Clear password.
                  set system password.
                  After press CTRL-Enter-Enter and 8-digit password.
                  Clear password.(Admin+system password)
                  Everyone thanks support!!
                    please generate a password for me
                    dell 16 digit hex bios password
                    428262F1F3F39528
                    Service Tag: GQB5242
                    thank you in advance.
                      428262F1F3F39528
                      Password : 98231710
                      In laptop: Type the unlock password and press <Enter>.
                        thank you sir,
                        but now the number has been changed please generate it
                        4E5E0329BAF6430C
                        SERVICE TAG GQB5242
                          thank you sir,
                          4E5E0329BAF6430C
                          SERVICE TAG GQB5242
                          Password : 53768911
                            Looking for help with resetting password for Dell Insporon 15-5575.
                              @alexinquest
                              Turn on the computer and enter the wrong password three times. This will lock the computer and display a "System Disable" key.
                                System desable - 2aa3e4089baeb030
                                service tag - f3dnfp2
                                plz sir send me password
                                  @joydip935
                                  Start with the NEW instructions to properly delete the password, if that procedure does not work then proceed with OLD instructions.
                                  Inspiron 5575
                                  Service Tag: F3DNFP2
                                  NEW Instructions:
                                  - Reboot or power-on computer.
                                  - Enter calculated password, press and hold left CTRL key down, press ENTER key twice (CTRL-ENTER-ENTER).
                                  IMPORTANT: Give it at least 3 tries before continuing with old instructions, as some newer models require this alternate procedure to properly clear the system passwords.
                                  OLD Instructions:
                                  - Enter calculated password and press ENTER key.
                                  master.password = 53915279
                                  Dell, System Disable: [2AA3E4089BAEB030]
                                    @joydip935
                                    If the previous password did not work, the code should still be the same, don't you think? Give it a try, enter 10-20 incorrect passwords, then check if the code had changed... nope.
                                    I believe that you did not read the instructions, that's what happened.
                                    Now that you know how to use the password, go to bios-pw.org and generate the password yourself.
                                      Originally posted by AAAC View Post
                                      @joydip935
                                      https://bios-pw.org/ WHICH CODE ENTER PLZ PLZ GUIDE ME
                                        Hi I hope this that isn't too old for me to get help with this...
