Any experiences with this ESR meter circuit?
    Re: Any experiences with this ESR meter circuit?
    I just discovered the beauty of google, but its a direct translation word for word.
    Can't make it out. Technical issues its not adequate.
    Need some technical mind.
      Have you translated the description PDF file in 2484_________.zip ?
        Try google translate.
        I'm having difficulty with attachments.
          You might have to copy out the contents of the PDF and manually paste them into Google translate?
          -David VanHorn
            Here is the translated file.
            Have fun.
              Can I use PIC18F2550 instead of PIC18F2520 in R2-D2 LCF ESR Meter? Please Help
                Hi Friends,
                Can I use PIC18F2550 instead of PIC18F2520 in R2 D2 LCRF_ESR Meter? Please help
                Javed
                  Probably you can but you may need to recompile the firmware and change some options to make it work on the different chip - and I have no idea what you would have to change.
                  -David VanHorn
                    I made one some years ago,the only problem was a bit of drift .
                    I fitted a small bulb in the oscillator ,that cirtainly made a big difference.
                    Pinched the idea from HP
                    Barry Wilkins
