Lenovo V510-15IKB LV6 corrupted BIOS
    Re: Lenovo V510-15IKB LV6 corrupted BIOS
    Originally posted by danro View Post
    Hi, thanks for answer.
    For sure is V510-15IKB. On the bottom case is a sticker with SN: LR08PWA9, ID:CS20, MO: LRNXB741000W.
    The spi flash was come with solder/desolder traces, so maybe not original content or have some modified blocks
    If need other info, please let me know
    Ok, this file has changed serial number.
    Become a Badcaps supporter
    Thanks to all supporters.
      thanks, but no changes, image only on external (
      the same problem with different dumps, so maybe hardware problem...
      this mainboard have Kaby Lake-U (SR2ZU) CPU and no AMD GPU
      all voltage is present, except +VCCGT
        [QUOTE=danro;1116271]thanks, but no changes, image only on external (
        if you have an image only on the outside, there is no problem with the bios ... check the display, LVDS cable, video chipset (probably detached balls between the motherboard and chipset, lack of chipset voltage) .... l
          [QUOTE=peste;1116274]
          already try with new LCD and cable, same result
          will reflow the CPU (that have integrated graphic)
            [QUOTE=danro;1116285]
            reflow it if you want to use the laptop as a door stop or big paperweight. Start a new thread in the main laptop forum if you want any more help, the bios is ok.
              [QUOTE=SMDFlea;1116286]
              ok, thank you!
                Re: Lenovo V310-15IKB please bios
                I have a Lenovo V510-15IKB.
                when I put the DC cord, directly the fan spins at max rpm without touch the power button. No leds, nothing. Only fan at max rpm.
                Possible Bios???
                I attach the dump of BIOS.
                Thank you
                  Possible Bios???
                  Thank you
                  Unlikely to be a bios issue. Check DC-IN mosfets,EC chip and look for liquid damage.
                    I need bios dump for
                    LENOVO V510-15IKB
                    Model Name: 80WQ
                    MTM: 80WQ00WWSC
                    F ID: CS20
                    SN: LR08AXZ5
                    MO: LRNXB722400J
                      LENOVO V510-15IKB
                      Model Name: 80WQ
                      MTM: 80WQ00WWSC
                      F ID: CS20
                      SN: LR08AXZ5
                      MO: LRNXB722400J
                      REV : F DA0LV6MB6F0
                      I try all files from thos theme and do not work for me.
                        Post your original corrupt bios file here.
                          I don't have it. I don't save it.
                            V510-15IKB Laptop (Lenovo) - Type 80WQ ( not have DMI )
                              I try it, don't work.
                                Re: Da0lv6mb6f0 rev : F lenovo v510-15ikb
                                Originally posted by Claudiomfa View Post
                                try and report
                                Thank you. %100 working
                                  da0lv6mb6f0 need ram disable
                                    Hello, can someone provide a file for this equipment my notebook have intel graphics only
                                    V510-15IKB
                                    80WQ
                                    MTM80WQ0000SP
                                    Thanks in advance
