Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Re: Extract bios password from EliteBook 840 G8 Bios dump, possible?
    Originally posted by synet2k View Post
    Hi, I need to dump both of my bios to file in order to unlock the bios? or I can just flash the file from post #54 will do?
    You need to dump both of my bios to file in order to unlock the bios.
    Code:
    No, don't do that.
    Become a Badcaps supporter
    Thanks to all supporters.
      I cant understand plz u rebuild this bios
      HP 840 G8 11 GEN PSWD
        What's your problem ? Bios corrupt or bios has a password ?
          this bios have password can u remove this password
          am waiting your reply thanks
            Description : HP EliteBook 840 G8
            CT Number : 6LGWR0EWYF795L
            Serial number : 5CG12869TG
            SKU number : 3E9K6UP#ABA
            Feature byte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVng.Q4
            Build Id : 21WWCVCT601#SABA#DABA
            Product Number : 3E9K6UP
              thanks Hoaca388
              my job time is finished
              I will check tomorrow and give you result,
                brother password is clear but its give manufacture mode error
                when i entered the information not save same error
                  Post data of 2nd SPI chip . It's 16MB or 32MB.
                    hello, i have an elitebook 840 g8 with bios pass, can u hel me ?
                      what should i do ?
                        Originally posted by Kicique View Post
                        what should i do ?
                        Buy a programmer, find bios and ec chips of device, use that programmer for read data from bios and ec chips , post both that files here.
                          HP Elitebook 850 G8 bios locked
                          Hello i have HP Elitebook 850 G8 bios locked need help please.
                            Re: HP Elitebook 850 G8 bios locked
                            Post 2nd bios chip.
                              Use the Rc unlock tool with the 16mb chip at the back of the board , works fine with 840 g7, i believe it will work fine with this too.
                              for easy access you can use the ic test clip probe,no need to take out the chip
                                Originally posted by hoaca388 View Post
                                post 2nd bios chip.
                                here it is the seconde bin
                                  Originally posted by udemzy View Post
                                  use the rc unlock tool with the 16mb chip at the back of the board , works fine with 840 g7, i believe it will work fine with this too.
                                  For easy access you can use the ic test clip probe,no need to take out the chip
                                  but it is 32 mb chip it won't work
                                    Post 2nd bios chip.
                                    Can you help me with that
                                      Ofcourse . In the first boot, you have to go into bios setting for dissable all the security options.
                                        thank you sir it works appreciate
                                          Please look for the 6050A3217501-MB-A011086 L2 file clearME
                                          840 g8 11th
