asus x512dk bios please
bios x512dk
Re: bios x512dk
Originally posted by ngohieu View PostWhat is your password ?
Islam is incorrectAttached Files
Re: bios x512dk
Hi all., can anyone do a cleanup for this Original BIOS dump file. With this original file, I see the White LED on the LHS glow up but still when I press the ON/OFF button on the keyboard, it does not turn on the motherboard, no increase of amp on the amp meter. I tried other BIOS dumps on this thread & other related threads, but believe it or not, NONE of them worked, the LED does not even glow in all other dumps. Mine is an ASUS AMD RYZEN 5., & on the keyboard connector pin 30 (Assuming this is the ON/OFF pin) I get 2.9v, is this ok??? Motherboard Part # X512DX Rev: 2.1 ... Thank you
Re: bios x512dk
Originally posted by mferna14 View PostHi all., can anyone do a cleanup for this Original BIOS dump file. With this original file, I see the White LED on the LHS glow up but still when I press the ON/OFF button on the keyboard, it does not turn on the motherboard, no increase of amp on the amp meter. I tried other BIOS dumps on this thread & other related threads, but believe it or not, NONE of them worked, the LED does not even glow in all other dumps. Mine is an ASUS AMD RYZEN 5., & on the keyboard connector pin 30 (Assuming this is the ON/OFF pin) I get 2.9v, is this ok??? Motherboard Part # X512DX Rev: 2.1 ... Thank you
Become a Badcaps supporter
Thanks to all supporters.
Re: bios x512dk
Originally posted by mferna14 View PostHi all., can anyone do a cleanup for this Original BIOS dump file. With this original file, I see the White LED on the LHS glow up but still when I press the ON/OFF button on the keyboard, it does not turn on the motherboard, no increase of amp on the amp meter. I tried other BIOS dumps on this thread & other related threads, but believe it or not, NONE of them worked, the LED does not even glow in all other dumps. Mine is an ASUS AMD RYZEN 5., & on the keyboard connector pin 30 (Assuming this is the ON/OFF pin) I get 2.9v, is this ok??? Motherboard Part # X512DX Rev: 2.1 ... Thank youOriginally posted by hoaca388 View PostLook for stickers and QR codes on the motherboard to accurately identify your model.
As @hoaca388 said before, see if you have any sticker on the motherboard contains (X512DA) or something else.
Also see if that Serial Number matching your Serial on the Laptop cover.
Serial Number: KAN0CV119744437.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: bios x512dk
Originally posted by mferna14 View PostThank you so much @hoaca388 @hardware1... attached are the photos of the only sticker at the back of the motherboard for you'll to review. Kindly view them.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Re: bios x512dk
Just now I programmed the new BIOS on post #10, It did not work. With this BIOS version I do not get the 3.3V & 5v, all gone. But with the Original one which I posted in #8, I do get 3.3V & 5V, the LED glow WHITE but still when I press the ON/OFF button on the keyboard, the motherboard does not turn on. Where is the Older Version please inform me, I will surely try that one. Thanks for the help.
Re: bios x512dk
Originally posted by mferna14 View PostJust now I programmed the new BIOS on post #10, It did not work. With this BIOS version I do not get the 3.3V & 5v, all gone. But with the Original one which I posted in #8, I do get 3.3V & 5V, the LED glow WHITE but still when I press the ON/OFF button on the keyboard, the motherboard does not turn on. Where is the Older Version please inform me, I will surely try that one. Thanks for the help.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Re: bios x512dk
Originally posted by mferna14 View Post@hardware1 thanks for the help, post #10 worked fine. Only my fault, I was programming on a 3v BIOS chip whereas I had to use a 1.8V chip. Once I got this chip, programmed the Bin Dump & all worked fine without any problem, really appreciate your help.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Re: bios x512dk
Originally posted by Patriarxis View PostHello .
This is my original bios but with this one i have no start up. i have all the voltages on the coils exept cpu coils and white led. i belive that is corrupted from bios update.
The serial of the laptop is KAN0CV11N581438.
