Dell Precision 7510 intermittent POST failure
    Hello all,
    i have troubles with Dell Precision 7510 board LA-C541P Rev:2.0 A01.
    It didn`t POST and it`s throwing 2amber and 1white code which is CPU failure.
    Sometimes it`s just start working when disassembled and put back again,but with a lot of BSOD when i tried to install W10,sometimes it is working completelly fine unless switched off.
    I tried to make some pressure on CPU BGA socket,but no change of behavior.
    BIOS has been programmed,also BIOS chip was changed and still nothing.
    Not working board just sit for a day or two and when i plug it,it just pass POST and it starts!
    Any ideas please?
    Re: Dell Precision 7510 intermittent POST failure
    Sounds like SOC issue??
      Sorry for late reply,still trying to manage what to do with it...
      Now it just sat for 2 weeks in shelf with other 3 laptops on top and it is working again.
      But when i try to connect with internal wifi it freeze the system almost completely...
      Without wifi connected works fine.
      Any clues please?
        So it is probably PCH problem,problems occur on PCI-E and SATA devices..
          Thats what i wrote in post#2
            Yes,thank you,you had a point.
              Hello all,still trying to make this machine work.
              I bought dead board where i found shorted high side mosfet on 1.2V RAM power rail.
              Mosfet removed and replaced,but there is very low resistance (about 5 Ohms,on good board is about 400) on rail leading to memory controller/cpu.
              On RAM power rail there are kOhms now (i removed solder from jumpers to measure power and controller side separatelly).
              Board power LED just blinks for a second and went off.
              Did i missed something or is it game over (dead memory controller/cpu)?
