Bios needed for Dell E6320
    Can some one please help me with the master password for DELL e6430 BIOS password.
    The BIOS is locked with admin password, without which I can't even change the boot sequence.
    The service tag is 9K7GWW1-1D3B
    The keyboard is QWERTY
    Thanks in advance
    Re: Dell E6430 BIOS help needed
    if you manage to find somewhere plzzx tell me to
      I think there is similar threads with same problem, so please use search. If i manage to find extra time, i will search it for you, but it would be at the end of the day.
      If everything else fails, buy the BIOS chip on ebay and replace it. It is a small cost solution.
        Here you go, it was just under this thread :P
        https://www.badcaps.net/forum/showthread.php?t=16965
        https://www.badcaps.net/forum/showthread.php?t=26981
          Originally posted by lord View Post
          Here is my research until now.
          Software solution
          1. Keygen: There is no public/free software solution for systems with Service Tag ending 1D3B.
          2. BIOS downgrade You have to downgrade to a previous edition of the BIOS whose last 4 letters of the Service Tag is 595B/D35B/2A7B/A95B etc. Then follow this free online service based on Dogbert's findings.
            The process (Works for D630... needs to be tested for E6430.. ) is as follows:
            • Take HDD out first or it can lock it.
            • Find .HDR file for old version of BIOS for example for Dell D630 its BRIS***.HDR Where BRIS is short name for motherboard dell codename BRISBANE. and *** = A08 version.
            • Put this file in USB
            • How to make HDR? On most dell systems, type the following in administrative command prompt
              Code:
              bios.exe /writehdrfile
            • Now take battery and power cord out, plug in usb.
            • Hold END and POWER Button while pluging in power cord.
            • Now battery light starts blinking red green purple means its flashing. 2 minutes and it shuts off.
            • Now its A08 and password should work.
          Hardware solution
          1. First solution presented by dycc in the post here requires taking the CMOS chip off the mobo and using the programmer to over write it with a clean image (.BIN file). The tool costs around £26 in UK but I have no idea where to get the clean .BIN file for E6430.
          2. Second option is uses a Ultimate Boot CD to clear the CMOS using the WipeCMOS app.
          I am tempted to try the second option, but In my case, booting from CD/ROM is disabled in BIOS.
          My boot sequence is 1. NIC 2. HDD 3. USB HD...
          If someone can help me with putting the Ultimate Boot CD image on USB to boot from it I may be able to test it.
            I have a E6430 which was also locked. It also had the ***-1D3B lock code. First of all the easiest way to fix this would be to chat with a Dell tech support rep who was able to take my code and generate an unlock code. It was free since it is still under warranty. This will save you a lot of headache. you can try the code I was given but I'm pretty sure its specific to the service tag number. Good luck!
            1Uv6017IUZN36T1h It is case sensitive and I had to hold ctrl while pressing enter.
              need bios for E6320
              l need clean bios for dell E6320
                Re: need bios for E6320
                What is the size of your bios ????
                  HI
                  i need bios password reset tool for dell latitude e6320 pls help me
                    Originally posted by repairs View Post
                    HI
                    don`t do that!
                      hi i have same model but it have bios password how to remove
                        you remove the bios with this tool
                        https://www.badcaps.net/forum/showth...hlight=utility
                          I need urgent help for my E6320.
                          7SNFCS1-1D3B
                          Anybody..please ???
                            7SNFCS1-1D3B
                            Anybody..please ???
                            her dump
                              Thank you.. Please advice on how to use this file..I am a novice when it comes to .rar files..
                                install WinRar, open with that program and just drag and drop
                                  La-6621p r1.0
                                  check ok working.
                                    Bios dump needed for dell e6320 mainboard is LA-6611p rev :1.0 thanks
                                      Re: Bios needed for Dell E6320
                                      try this working.
                                        it is not for LA-6611P board it working on LA-6621P mainboard .is any one have bios for LA-6611P bios dump
