Thread Tools | Display Modes |
#1 |
City & State: Sakon Nakhon
My Country: Thailand
Line Voltage: 220VAC 50Hz
I'm a: Hobbyist Tech
![]() Hi, I have a 24v 600w SMPS from a cnc/engraver machine. It has stopped working, No power from the supply. I opened it up and found the main rectifier, 2 mosfets, and 2 current sence resisters all blown. I can find the bridge rectifier and resistors but not the mosfets. They have the number 600R160 on them but i searched everywhere on internet but unable to find any datasheet or info to get equivalent. The only reference I can find to 600R160 is for resetable fuses. Can anyone advise me as to what a replacement might be. I have attached photos if its any help. Thanks in advance for any info.
#2 |
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
![]() This is something that need to brought in this post because this brand of power supply are found for a lot of engraving and 3D printers so if you are having this issue already this might start popping more often
Thank you for posting this issue with your switching power supply for your machine Because I have this same exact brand on my 3D printer but I have recap mine already I do not recognize the ic manufacturer logo on this device but I suspect that it is priority in nature and you might not find a replacement for it unless you can find another circuit diagram that is very similar to the circuit board design that you have in this switching power supply board You might be better off buying a mean well brand switching power supply and try to buy one that has a higher current capacity than the one you have or at least the same current capability If you can not find one and you have to buy the same brand again recap the switching power supply board with name brand capacitors so you can avoid failure like this in the future before you even plug it in for the first time But if mine has a failure like this I already have found a replacement for it and I am posting a website link to it https://www.ebay.com/itm/16409247129...53.m1438.l2649 Yes they are a little pricey in nature ( for even a new one ) that is why I have this item in my wish list You can find these switching power supply on the internet and should be easily found
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() Last edited by sam_sam_sam; 11-20-2021 at 06:56 AM.. |
#3 |
City & State: Málaga
My Country: España
Line Voltage: 230VAC 50Hz
![]() The manufacturer of IC is "Wu Xi China Resources Huajing".
It seems to be hard to find on the internet. Source: http://www.ecadata.de/herst/myshowlogo.php?F_SPRACHE=2 Can you measure the size of the mosfet? I am not sure if they are mosfet, because the part number does not match other mosfet part numbers from that company. They use "N" between the numbers instead of "R". If those are mosfet they are probably 600V 16A. Maybe you can replace with one with the same or greater parameters and check if its work. An example: STW25NM60ND |
#4 | |
My Country: USA
![]() Quote:
#5 |
City & State: Sochi
My Country: Russia
![]() 600r160 - hpf600r160pc-g
#6 |
My Country: USA
#7 |
![]() Thanks to everybody for all the replies and info. I should be ok finding an equivalent now. I have already got a replacement complete supply from the machine manufacturers under warranty but still would like to fix the old one for a spare in the future.
#8 | |
My Country: USA
![]() Quote:
But I would highly recommend that you recap this board before you really start using the replacement one because they have off brand capacitors and there are know issues with quality of them If you want a list of good quality brands and what series to use for this switching power supply just post a picture of the capacitors that are in this switching power supply Last edited by sam_sam_sam; 11-20-2021 at 12:44 PM.. |
#9 |
![]() I also found a video on YouTube by a crazy Czech guy about a write up and test of 600w 12v Smps which looks almost exactly the same as mine apart from the input filtration. This one has IRPF460A mosfets. I will check these out for similarities to mine I watched a lot of his videos and although a bit crazy he seems to be quite a knowledgeable and entertaining chap. The first photo is mine and second is his.
https://youtu.be/DzM3-bnotgQ I also have a couple of bulging caps to replace. |
#10 | |
![]() Quote:
#11 |
My Country: USA
![]() Yes I have seen his videos before and he is a little nutty but I do get a lot out of his videos that I have watch before I do not think I have seen this one though but I am going to watch this one as well
#12 |
![]() There are 3 videos on this one supply: what’s inside, full load test and analysis+transformer autopsy. Very interesting.
#13 |
![]() Here’s the pics of my capacitors. The supply was for a Hictop Idex 3D printer, not CNC/engraver as I originally said.
#14 |
#15 |
My Country: USA
![]() Yes these are non brand name capacitors but if they are the main filtering capacitors they might be alright but if they look swollen in any way do not trust them to be good anymore any capacitor that it’s voltage is less than 100 volts I would highly recommend that you replace them with name brand capacitors if they have a UF value of 100 or less replacing these are very important to be replaced
#16 | |
City & State: Jakarta Pusat
My Country: Indonesia
![]() Quote:
![]() Most chinese smps use surplus component, so let's say they have big surplus of E13009 in China, well they will use E13009 almost in every design of their power supply.. That's why they tends to keep up the lowest price, and actually it helps a lot e-waste |
Thread Tools | |
Display Modes | |
