Hisense LTDN55K321 Purple backlight?
  • Daveatfernie
    • Nov 2013
    • 70
    Hi Everyone,
    Hot on the repair of my plasma I found a 55" 4K LED backlit hisense tv for £40 on facebook that would be great for a garage TV if I can get it working correctly. The listing said it had a purple tint (and it does indeed).
    When I've powered it up and looked through the vents in the rear the backlight can indeed be seen to be purple rather than the usual crisp white I'm used to seeing. Is this a thing? Can all the LEDs change colour like that? I use high power LEDs where I work and am used to seeing a few nm drift in colour when they get hot but to go from white to purple? I Imagine that if I replace the backlights it would give me a nice picture as this is it's only problem but is it something that's seen often?
    Thanks in advance once again.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Hisense LTDN55K321 Purple backlight?
    I'm used to HPS going from white to a vivid pink and I suspect that's normal for some HPS light bulb manufacturers and for some, it means a faulty HPS bulb or ballast, LOL.
    Purple for fluorescent, like the earlier LCDs, is typical if failing or a bad inverter.
    And for the frosted mercury vapour light bulbs used for street lights and gymnasiums, they're purple when not warmed up. (a.k.a. colour-corrected mercury vapour)
    For LEDs, I dunno...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • budwich
      • Jul 2015
      • 3097
      there are threads here about "purple leds" problem... basically, you need to replace them.
      • Daveatfernie
        • Nov 2013
        • 70
        So indeed the back light had turned blue/purple. It seems that there's no real thermal junction between the LED boards and the back panel other than periodic screws to hold them in place. Something I'll remedy if I replace the LEDs.
        While the swap out would normally be a cut and dry affair during disassembly I found that there was a strip of adhesive connecting a small part of the front bezel to the LCD panel itself. Had it been all around I'd have been fine as I'd know to expect it but it wasn't and I didn't.
        I managed to damage the very bottom right corner of the panel as a result. While the panel is still working there's a small amount of bleed through in this location. I was hoping to give my mother in law the screen to replace her aged 32" Polaroid but I imagine it will be a screen for the kids to use instead. It may be that if I made a frame I could lose the bottom inch of the TV in the frame to hide it.
        So note of caution, beware the odd piece of randomly placed tape.
        Also the screen on this TV is sooo thin. I assume to minimise loss through the glass but the amount of flex was unreal. I had to remove the panel by turning the TV up on it's side and carrying vertically.
          • 12090
          • U.S.
          Grab some suction cups from harbor freight or ebay for your next one.
          • Diah
            • Feb 2013
            • 6355
            this is not as you thought Purple LED. you have one shorted or open LED which cause the PSU drop down the current to the LED strips so some of them lid in this way. i didn't find you were measure the current out of he LED from PSU Socket. just the eyes judgments
              Originally posted by budwich
              there are threads here about "purple leds" problem... Basically, you need to replace them.
              +1
              • budwich
                • Jul 2015
                • 3097
                just for the record, in case some one is searching.... but agree that maybe just a string in this case.
                https://www.badcaps.net/forum/showth...t=weird+purple
                  There is another thread too about purple LED's glow, I just cannot remember whom beside Michale32086.
                  • ducky29
                    • Dec 2015
                    • 370
                    • Europe
                    It was Dannyx with blue leds.
                    https://www.badcaps.net/forum/showthread.php?t=74697
                      • 12090
                      • U.S.
                      Over time, the yellow phosphor will degrade and all you have left is blue light, which can look purple too. THAT is the science of it, those that think otherwise need to look it up.
                      • Diah
                        • Feb 2013
                        • 6355
                        sorry... what are you talking about ? yes Hisense LED wasn't pure white since beginning , they draw black circle over the strips to enhance black level only , also the black some time look little to blue. but this not the case over all links provided over here.(2018-2019 ). in 2017 i had Hisense under my hand and i was very deep searched ( https://www.badcaps.net/forum/showthread.php?t=62117 ) till the LED back light. .. let us talk sense.. not stories of fiction
                          • 12090
                          • U.S.
                          NO FICTION HERE, Just look it up, it's not rocket science just led science. Pretty basic shit, not hard to understand at all. If you don't know the facts of something try doing some research before getting frustrated and showing ignorance by running your mouth about fiction.
                          • guix
                            • May 2018
                            • 25
                            • France
                            Thanks Daveatfernie for the warning, I have the same TV and need to replace the LEDs too (not blue, simply no backlight at all), so I will make sure to look for this piece of adhesive...
                            Can you please tell me the reference of the LED strips so that I can buy them before opening the TV ? As I don't like to open multiple times or leave it open collecting dust while waiting for the LED strips to come.
                            • guix
                              • May 2018
                              • 25
                              • France
                              In fact I have opened the back of the TV and tested the backlight with GJ2C tester, and the LEDs are working but they are all blue too! The tester shows the same voltage for both LEDs channels, and multimeter shows only 1V coming out of the LED connector on the PSU, so additionally to replacing the LED strips I have to repair/replace the PSU... After a bit of testing I couldn't find something wrong on the board, so I suspect it's the LED driver (LX27901ID) that is faulty, I will try replace it just for fun, the board is only 15€ on aliexpress
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                Its the Leds no the board. I have encountered this problem a dozen times.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  https://www.badcaps.net/forum/showthread.php?t=80139
                                  Yellow filter crumbles away causing blue/purple color.
                                  • guix
                                    • May 2018
                                    • 25
                                    • France
                                    But the output voltage stay at ~1V when I turn on the TV with the LEDs disconnected, it should be around 170V normally, so there is a problem on PSU, no ?
                                    • ojmc
                                      Hisense 65H6570G - Color inverted after replacing LED backlight
                                      by ojmc
                                      Background:
                                      • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                      • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                      • The TV worked again perfectly for ~2 weeks.
                                      • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                      10-17-2024, 02:29 PM
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                    • hollox123
                                      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                      by hollox123
                                      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                      1. Laptop keyboard doesn't work
                                      2. The backlight on the laptop keyboard doesn't work
                                      3. The x2 side LEDs (red) on the laptop don't work
                                      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                      But I am strongly aiming that it is somehow a BIOS-related problem,...
                                      05-11-2025, 08:05 AM
                                    • signal.quest
                                      Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                      by signal.quest
                                      I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                      03-17-2024, 10:14 AM
                                    • Mschrenkz@gmail.com
                                      Hisense 60R6E - No backlight - stuck in boot loop
                                      by Mschrenkz@gmail.com
                                      I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
                                      05-09-2023, 08:53 AM
