Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 10-27-2021, 02:57 PM   #1
Ritchie_Uk
Prawnography
City & State: London
My Country: Uk
Line Voltage: 240VAC 50Hz
Default Duracell Battery Charger - CEF22GBL-3
Hi there - I am searching for a Duracell CEF22GBL-3 Battery Charger
Its nothing SPecial, but on this Charger, there are 4 AA Bays and 1 9Volt Bay.
The 9 Volt has stopped working, but the Rest seems Ok.
1. Does anybody have a Schematic for this please, as I dont want to throw it away?
Ritchie_Uk is offline   Reply With Quote
Old 10-27-2021, 03:41 PM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: Duracell Battery Charger - CEF22GBL-3
Post some pictures of the board both sides of it
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 10-27-2021, 07:38 PM   #3
Ritchie_Uk
Prawnography
My Country: Uk
Hey Sam_Sam_Sam I will do,
I have been engrossed in trying to repair this.
It seems to have a Processor IC.
This is the Model, well mine is a lot older, but looks almost identical
https://uk.rs-online.com/web/p/battery-chargers/7698761
Will Post Pics in a minute
Old 10-27-2021, 07:52 PM   #4
Ritchie_Uk
Prawnography
My Country: Uk
Here are the Photos
In Pic 2 D5 and Q1 have been taken off
The Main Semiconductors are
Big IC - IC EM78P374NS024J
Input Area - AS393M
Input Area - A04409
I cant seem to find Schematics anywhere for this unit.
Old 10-28-2021, 12:23 AM   #5
sam_sam_sam
This part number does not come back with anything
EM78P374NS024J
Either it is in-house part or some other issue
Old 10-28-2021, 12:26 PM   #6
redwire
City & State: Alberta
My Country: Canada
EM78P37x is Elan Microelectronics 8-bit OTP MCU, I think 4KB ROM for the 374.
It's a MCU custom programmed for this application. You'd have to draw the schematic, I've never seen anything published out of china or taiwan for fear of copying.
There's really no solder on the through-hole pad by R49 to B1N, and bad soldering to big through-hole parts is a common problem to look for.
How are the electrolytic capacitors? It is powered by a wall wart? Wondering if it has the 9V power it needs.
redwire is offline   Reply With Quote
Old 10-28-2021, 05:42 PM   #7
Ritchie_Uk
Prawnography
My Country: Uk
Hi Sam and Redwire - Thankyou
I have gone through every component, and they seem fine/
The 9V section isnt working.
The EM7 seems to be here and "Seems" to look similar
https://datasheetspdf.com/pdf/924729...cs/EM78P374N/1
Its Cheap and throw away, but I dont want to throw it away, even tho I already have some new chargers I have ordered.
Old 10-28-2021, 05:44 PM   #8
Ritchie_Uk
Prawnography
My Country: Uk
ps I am running the Charger with my PSU, its 12V and about 1 Amp
Old 10-29-2021, 09:50 PM   #9
Ritchie_Uk
Prawnography
My Country: Uk
What’s useful?
Old 10-29-2021, 10:08 PM   #10
redwire
My Country: Canada
Just a spammer.
Does the charger have a single 9V port? You could follow that back to the PC board and see what mosfets they are using for switches there. I imagine it's easy to connect one backwards and maybe that damages a unit?
Old 11-02-2021, 04:50 PM   #11
Ritchie_Uk
Prawnography
My Country: Uk
Thankyou Redwire
Sorry for the delay in responding, but I have had so many shifts in the last week.
I need to focus on the circuitry,, and try and work iut why the 12 Volts befor the diode is Ok, then After the diode, which I am unsure of they type, possibly a Zener is Zero volts.
It seems like the main IC is really complicated for what it does, as I have had the charger for at least 10 years.
The clue could be that I have had so many problems with the 9 Volt section anyway.
It’s incredibly complicated for a small unit.
I remember reading the fact that Duracell don’t build there own units, but the exact clone is under another name,
I forgot but will search my web history
Will keep yiu updated
Old 11-02-2021, 04:53 PM   #12
Ritchie_Uk
Prawnography
My Country: Uk
ps Redwire it can also Charge AA and AAA and the massive ones no one can ever remember what they are called ��
Old 11-02-2021, 05:09 PM   #13
redwire
My Country: Canada
Duracell does have a long "guarantee" on these I think 7 years so maybe hit them up for a replacement. Not sure how they are in the UK for consumer protection.
Wild guess is whatever modulates the 12V down to 9V, might have croaked. Like a small mosfet. But the charger also has some safety routines in the MCU so it will not initiate charging unless safe (i.e. sees say 6V) and the current is not too high. So your charger circuit might work fine unless you fool it properly with a dead 9V battery, or spoof it.
Old 11-02-2021, 05:45 PM   #14
Ritchie_Uk
Prawnography
My Country: Uk
Hi Redwire
Bless, you this Charger is the Workbench first thing in the morning, as I wont let it beat me.
I will keep you updated, as I am off for 2 days now
Regards
Old 11-04-2021, 11:56 AM   #15
Ritchie_Uk
Prawnography
My Country: Uk
Hi Redwire - As promised an update
I have made contact with some helpful people who will attempt to source a schematic for me,
If they manage, I can pass whatever data and info if you need.
Regards
Old 11-08-2021, 09:40 PM   #16
Ritchie_Uk
Prawnography
My Country: Uk
Hey Redwire - The Unit is Working now as I believe the Diode I removed was intermittantly breaking down.
Under normal conditions I found no components Shorted / Open, which was frustrating.
The only thing I havnt tested is whether it shuts off when the Battery is Full.
The 9 Volt is Charging, but the Charging light stays on.
Its amazing how complicated the Logic section is.
I still havnt recieved the Schematics yet, but if you need any Schematics, and I have many please just ask, as I have 1000's and 1000's
Regards and thanks for your response
Stay Safe
Old 11-08-2021, 09:41 PM   #17
Ritchie_Uk
Prawnography
My Country: Uk
ps - If you look at Photo 1 of 4 it was Q1 and the Diode just above it that was breaking down
Sam-Sam-Sam also I really appreciete your help as well
Old 11-10-2021, 02:04 PM   #18
redwire
My Country: Canada
I bought an Energizer ENC-2A car battery 2A charger/maintainer and played around with it and found out the software was terrible.
It would not start charging unless the battery passed a little test it did. Firmware looked at battery voltage and tried charging for a couple seconds and if it was not satisfied, it went into a fault/lockout condition and you'd have to reboot it to do anything else.
I took it back to the store for a refund because it would not charge gel cells or anything sulfated, and it also had a bunch of software timers where it would charge for a minute then think it's done.
It's not going to burn the house down or wreck the car so why all the bimbo firmware? They must get paid a lot whoever designs these in china.
Old 11-11-2021, 08:39 AM   #19
Ritchie_Uk
Prawnography
My Country: Uk
Redwire oh really?
Weird that they used software, would an Op Amp or Comparitor have done the trick?
Ansmann and a Dlyful - The Ansman is really over priced and not great if you need advice or support.
The Chinese reverse engineer things, some of the designs I have seen were so bad that we sent people over to oversee them
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
