Thinkpad Carbon X1 2nd Gen - Broken ?
    Hello ,
    I have an Lenovo Thinkpad Carbon X1 2nd gen. When i press the power on button the fan cooler swipes for about 5 seconds , the backlight of the keyboard turns on and off , the touchbar working.
    The cooler after 5 seconds stops , and no video even on display even on HDMI.
    I allready tried to reflow the RAM , and worked for about 2 - 3 times. After that stopped working , tried again to reflow but nothing. Is there a way that the RAM memmory to be burned now ?
    Somebody got succes with this problem ?
    Thank you
    Re: Thinkpad Carbon X1 2nd Gen - Broken ?
    1) What is the history of the laptop? Any liquid spills or just started doing this today ?
    2) Remove all power (no adapter / no battery). Meter in resistance mode.
    Measure and post the resistance of each coil to ground. Searching for any super low resistance values on the logic board which may indicate a shorted capacitor = local power rail will then shut off to prevent damage due to the high current draw of a shorted component.
      Hello , i don't know the history of the laptop , because i had bought without screen for repair. But i see that not only the screen was the problem. But didn't see any signs of water.
      But why after the first reflow , the unit botted and i can enter the bios ....
        Memory is the main issue with them. Maybe try reballing. Seems kinda pointless tho.
          Well , news.
          I had tried with another board that has the same problem.
          Flux + Heat , and now it's runs , but there is a strange thing.
          You push the power button , and takes about 30 - 40 seconds for immage to appear , after that it's runs aprox fine.
          And another thing , if loads Windows or Linux , and you don't use it , right then it freeze , if you run it then it's works ok.....
          You have some ideeas ? Problems with the RAM ?
            Is it intel board? Then the delay is probably bad me region of the bios.
            Clean me region if its is intel board.
              Hmmm , how can i check if it's an intel board ?
                Which processor is in the board is it intel i7 or i5oramd processor.
                  It's an I5 4300U with 8gb RAM
                  I have those info's from AIDA
                  Bios Type - Phoenix UEFI
                  Bios Version - GRET63WW 1.4
                  SMBIOS Version - 2.7
                    Ok do clean me region from your dump or ask here for cleanme region of your dump.
                      SO first of all , i need to read the dump from the eeprom , right ?
