what to do with faulty hard drives?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
    i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me who are budget conscious? if there arent any ideas im afraid the most cost effective way for me to deal with the drives will be to send them off for scrap at the e-waste recycling box in my neighbourhood....
    • 30965
    Re: what to do with faulty hard drives?
    sell the boards - people buy them for data recovery
    • diif
      • Feb 2014
      • 6978
      • England
      There's some value in the PCBs for data recovery, but they would take time to sell. You could try and sell them as a job lot locally, otherwise I'd say they're scrap.
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        get the magnets out of them and scrap the rest . or maybe make clocks with the discs then scrap the rest
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8067
          That's what I do too. On internally broken HDD's, I take the board off and scrap the rest.
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            Take the PCB off and save it. Curie the platters and bin it.
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              I take them to the rifle range for local law enforcement, they use them for target practice.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • desert-rat
                • Mar 2014
                • 4103
                A number of years ago a guy was buying a bunch of used but stil good HDD 3 1/2 as I remember in the 60 to 100 gig range . At a local used comp. place. When asked he said they were for target pratice . I dont know if he was seoiuus of joking .
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1865
                  • Romania
                  Sledgehammer then to oblivion.
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    just one more question tho, if the hard drive is focked, how do i know its not the pcb that is causing the hard drive to be focked? if i sell the focked hd pcb then what if the buyer complains i sold him a defective pcb?
                      • 30965
                      afaik most drives store their settings on the platters
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        Well, if it's not too late, I strongly recommend trying this out:
                        ... image taken from this thread/post:
                        https://www.badcaps.net/forum/showpo...2&postcount=53
                        Believe it or not, I've been using the HDD "bench grinder" above fairly frequently. It's very useful for sharpening things like dull drill bits, chipped flat heat screwdrivers, and sharpening blades. Also used it to smooth out a few acrylic glass shims I was making for a CPU bracket riser. The current sandpaper I have on there is fairly rough and will eat wood and plastic / acrylic, and aluminum pretty quickly. I also have some finer sandpaper and was thinking to glue to another platter so that I can swap between different sandpaper grit when I need "finer" sharpening. But if you have multiple HDDs, you can just make multiple sanders, all with different sandpaper grit. The neat thing about this project is that you only need an ATX PSU and can literally move/use the HDD grinder anywhere.
                        On a side note, if you do build one, make sure you wear safety glasses when using it. I've had mine grab a small aluminum piece one time when I was not careful, and it shot it quite energetically across the room. The spinning mass of several metal platters @ 7200 RPM is not to be underestimated. While it won't have anywhere near the power of a real grinder, it can still be dangerous. Adding a flat "table" surface in front of the grinder should make it safer and is recommended... but I'm too lazy for that.
                        That's another excellent use of old HDDs that don't have much value (e.g. low capacity HDDs, especially IDE/PATA.) Their magnets are pretty strong - great for extracting screws from deep holes in devices, finding lots screws (or other metal bits) on the floor or if fallen in a hard-to-reach place, and for magnetizing cheap screwdrivers that don't have magnetic bits.
                        Oh, and one more thing: rip the "voicecoil" on the hear arm. These usually have 5-10 Ohms resistance and are handy if you need a power resistor in that range. Just solder some wires to the ends and dump in a cup of water (distilled preferred, though not necessary.) That should make it able to handle at least 5-10 Watts continuously for a very long time... or at least until the water starts to bubble too much around the coils.
                        Or you can use the voicecoil as an electromagnet in a hobby project.
                        The platter motors can be fun too if you have a 3-phase brushless controller for an R/C car.
                        The PCB is a good source of SMD ceramic caps and resistors. Actually, on that note, if you have any old IDE WD drives in your dead stack, let me know. I'm looking for a particular motor driver controller for a dead 40 GB WD HDD.
                        • desert-rat
                          • Mar 2014
                          • 4103
                          Many years ago a guy told me he liked to hook 120v on small speakers . They used to make small hand held radios that used them. (1960s) He said they would give a loud buzz 4 a few seconds.
                          • eccerr0r
                            failing hard drives after sitting for years...
                            by eccerr0r
                            With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                            Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                            Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                            03-02-2023, 10:33 AM
                          • abajor
                            Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                            by abajor
                            I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                            I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                            The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                            Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                            04-23-2024, 11:43 PM
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            Hi everyone,
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                          • NeedsPractice
                            Best Overall Amazing Back Up Setup? 1K-4K Budget! Software + Hardware? Help!
                            by NeedsPractice
                            I remember a lot of people before when my hard drive failed told me that I could do a couple of amazing things with backing up data. What stuck out is two things...
                            1. Software that will backup your data live via a cloud solution or over the internet without having a corporate cloud product.
                            2. Get a storage tower with hard drives and load them up.
                            What I mean is there software out there that you can install on your computer. You tell it which data you want backed up. Lets say your main PC with (2) hard drives and (8) hard drives connected to it via a tower....
                            06-23-2023, 05:26 PM
                          • Nick Nougat
                            Siemens Gigaset DA810A landline telephone with answering machine resets every minute
                            by Nick Nougat
                            I'm posting this here since there does not seem to be a more fitting category.
                            The Device
                            The Gigaset DA810A is a landline telephone with an LCD screen, an answering machine and integrated telephone book. I have the version for the European (i.e. German) market.
                            It has two separate modules that can operate independently of each other: One is the basic telephony part that always works and is powered by the DC voltage coming through the telephone wire. It relies the TEA1110A telephone transmission and dialler chip for that.
                            The 'smart' part of the phone with the answering...
                            04-01-2024, 04:00 PM
