Macbook pro M1 A2338 820-02020 Liquid
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    The board has gotten wet, you can see it in the pictures. The display stays dark! No backlight. I think I have to bypass the front of the needle point too? Unfortunately I don't have a board view for my A2338! Is there a chip in the picture for the backlight?
    • 20441
    Re: Macbook pro M1 A2338 820-02020 Liquid
    schematic + boardview - https://www.badcaps.net/forum/showthread.php?t=97725
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      thx but its a BVR and I have openboardview.
      • andreacero
        • Nov 2021
        • 1
        • Italy
        Hi guys, I have a similar problem, macbook pro M1 liquid damage.
        My type c tester says 5,125 V, no short on logic board, power manager isn't too much hot 30 degrees.
        What can I do?
        • bigbadbios
          a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
          by bigbadbios
          I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
          When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
          I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
          Your help is GREATLY appreciated. Thanks!
          08-18-2024, 05:47 PM
        • dbuergi
          MacBook Pro A2338 liquid damage repair for a beginner?
          by dbuergi
          i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
          I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
          Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
          I fixed other laptops but this ist my first apple device ....
          07-24-2024, 09:48 AM
        • fajfelek
          Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
          by fajfelek
          Hello, First of all thanks you for reading this topic.
          I need your help with identify missing parts on trackpad logic board (661-18430).
          The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
          Please help me with identity parts from blue and red area .
          06-15-2024, 01:41 PM
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • classicandy
          MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
          by classicandy
          Hi Everyone,
          Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
          UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
          04-14-2024, 12:00 PM
