Desoldering help
  • Canuckled
    • Oct 2021
    • 6
    Desoldering help
    Hi. I'm new to soldering. I'm trying to remove a part from a board, so I can replace it with a new one, but I am having trouble trying to remove the old one. I have tried using flux with a de soldering braid, but it doesn't seem to want to remove all of it.
    Any suggestions?
  • Canuckled
    • Oct 2021
    • 6
    Re: Desoldering help
    I added a link for a picture, but I’m on mobile, so I hope it works.
    • clearchris
      • Dec 2013
      • 687
      IHMO, removing solder to remove a part can be the wrong strategy. You want to flood the part with solder so that your iron makes excellent contact with the puddle and the puddle transmits the heat into the board. I'll desolder joints to remove parts, but it's pretty easy with a heated desolder gun or even a desolder plunger pump. If I didn't have either, I'd use some PB solder to bring the melt point down a bit, keep it molten while I back the part out. Then I'd clean the solder out afterwards. Or sometimes, on a particularly stubborn board, I might keep the puddle melted and insert the new part through it. Kind of a pain, but sometimes you have to do what you have to do.
      Of course, I'm assuming a two pin through hole device. I can't see any pics, so can't really give tailored advice.
      • Canuckled
        • Oct 2021
        • 6
        I added a link to the picture on imgur.
        I was going to try that, but like I said, I’m new to soldering. I have a great soldering gun, and all the other stuff that is needed. From the picture, it looks like I’m getting to the bare bones, but I just can’t get that last little bit.
        • petehall347
          • Jan 2015
          • 4425
          • United Kingdom
          that would remove easier with hot air . or maybe chipquik
          • diif
            • Feb 2014
            • 6978
            • England
            I'd use hot air to remove connectors, then braid to clean up the left over solder.
            • Canuckled
              • Oct 2021
              • 6
              Ok, how would I do that? I have a hot air gun. Would I just put flux on the contact points, and heat it up?
              • diif
                • Feb 2014
                • 6978
                • England
                Depending on the connector I add leaded solder or low melt solder using an iron. Then I use hot air to remove the connector. I don't use flux when removing stuff.
                • Canuckled
                  • Oct 2021
                  • 6
                  Ok, thanks for the ideas. I’ll give it a try tomorrow and see how I make out. The stuff on the top has come off, but not the bottom stuff.
                    • Jul 2011
                    • 6027
                    Or if you have a soldering tweezers would also work but you would have to add some more solder to the mounting tabs and pins
                    Or remove the solder from the pins and add more solder to the tabs and remove the part when the solder has melted and is flowing
                    Which ever method you decide to do you will have to use more heat maybe as high as 800*F make sure your tweezers are up to temperature before you start
                    If you use a temperature controlled hot air gun turn up the heat and turn down the air flow but do not turn the air flow to low and do it from the back of the part too the edges of the board and keep moving around the part until it comes loose from the board
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • corrize
                      Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                      by corrize
                      Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                      There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                      I have :
                      - hot air, and a
                      ll stuff around
                      - true kapton tape
                      - 140 and 180 degree soldering paste
                      - bismuth
                      - little hot plate 250 degree max
                      - the new BGA chip with probably
                      05-20-2025, 01:26 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • STKR123
                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                      by STKR123
                      Greetings badcaps community,
                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                      I learned that desoldering...
                      10-29-2024, 06:03 AM
