a1297 slow cpu battery not charging but detected
    Hello anyone can guide me to this issue, macbook a1297 5 white blinks, then starts ok, gpu still alive,
    .. laptop works fine but no amber not charging but bat is detected in mac os high sierra, and says 68% but removing magsafe cable it turns off instantly
    It is a 2010 macbook pro a1297 820 2849...
    Is this a sensor issue? Or a bat issue? Thanks a lot!! cpu is performing quite slow...
    Pd of course original 85w charger, fans runs normal not 100%, and did test ASD (diagnostics ASD OS 3S138) for this macbook , and was all ok i think.
    Marcelo J
    Re: a1297 slow cpu battery not charging but detected
    Any hint to help determine if problem is battery or motherboard.mm?
    Marcelo J
      Sounds like a bad battery. How many charge cycles on the battery? Test with a known good battery.
      See here for more details:
      https://youtu.be/LlWs1_ZksIc
