Need software for Intelligent universal programmer lk48
    Re: Need software for Intelligent universal programmer lk48
    i think that works with both interfaces
      actually it looks like the fuckers have removed all the XP versions from the downloads!
      i may look at wayback-machine later.
        This version have both folders
          no, single folder with the usb version in it
          i think the download should be over 20meg
            Here we go again:
            1. Download:
            'LT**UXP_1300_WIN7.exe' (~12.5MB)
            or
            'LT**UXP_1300_WIN10.exe' (~12.6MB)
            2. Install.
            3. Check installed folders ...\Labt00l-**UXP, and ...\Labt00l-**XP
            Either win7 or win10 installation file will create both folders.
            4. Patch the exe file:
            For 'WLT**XP.exe @0x0003DF80 from 0x55 to 0xC3
            For 'WLT**UXP.exe @0x0043DEF0 from 0x55 to 0xC3
            And again, please do us all an obvious favor:
            - Don´t post obvious strings: Advant3ch 3quipment, labt00l, ...
            We really do not need the devil's search engine to find us...
            - stop attaching large files widely available on internet to posts.
            - use g00gle
            - DIY - ALL information you need is here
              Originally posted by megaraider View Post
              Here we go again:
              1. Download:
              or
              2. Install.
              - use g00gle
              did you just do that or just print it?
              i downloaded about 8 versions yesterday and none created 2 folders anymore!
              i also tried the version from DataMan and got the same problem.
                Originally posted by stj View Post
                did you just do that or just print it? [...]
                Did it all myself yesterday, top to bottom! [Copy / paste is not my style ]
                ALL fully tested under W7
                  from ADV??
                    from ADV??
                    Yes, follow the 1st link on your own post.
                      i did, i'm getting a 12gig file that only installs 1 folder with a usb icon.
                        LT**UXP_1300_WIN7.exe (CRC-32: 567212F4)
                        Installed folders ...\Labt00l-**UXP, and ...\Labt00l-**XP:
                        See screen capture files attached.
                          o.k. i have other problems then, fucking windows is screwing around.
                          i'll take notes and open a thread for it
                            Just a hint: try installing previous versions and watch the behavior. If problem persist then it's, most likely, win screwing around.
                              Originally posted by Skybug2 View Post
                              did you manage to find a valid license file or a patch to use the software Labtool uxp or dataman?
                              thanks
                                xp48 programmer
                                just read some interesting shit at the makers site,
                                with the latest software releases you MUST use win-XP and it MUST be 32bit or the installer wont install the parrallel port software.
                                if your on Vista or newer and/or running 64bit it will ONLY install the UXP usb-port software version!
                                i suspect it's because they use a 3rd party parrallel port driver from jungo.
                                  Re: xp48 programmer
                                  Thanks, good to know.
                                  imo it would be more helpful if you move your post to the 'original' thread.
                                    Re: xp48 programmer
                                    only a mod can do that.
                                    it does explain that arguement we had over wether they had removed the parallel port version or not.
                                    i was unpacking it with win7 64bit and you obviously had the last decent o.s. m$ ever made
                                      Re: xp48 programmer
                                      Yes it does clears it up
                                      Took a look at their site and they do mention:
                                      Parallel port: Windows 2000 / XP / Vista(32bit) / 7(32bit) / 8.1(32bit) / 10(32bit)
                                      USB port: Windows 2000 / XP / Vista(32bit) / 7 / 8.1 / 10
                                      and the same sh1t at license page.
                                      Those bastards charge a fortune for the software license and yet they don't want to pay JUNGO for a one time fee to use newer version (latest 16.10).
                                      They're still stuck with version v5.0.5 released in 2002!!!
                                      imho overwriting *.sys files with a licensed newer jungo version might do the trick... (plus writing the ...\Labt00l-**XP folder from a supported win 32 bit version installation).
                                      Alas i don't even know if only the last step is need (not tested) providing you also copy & paste the *.sys files to the %windir%\system32\drivers\ folder.
                                      P.S.: I'm still thinking these should be moved to the 'original thread' where it'll be more helpful...!
                                        Re: xp48 programmer
                                        installing on 32bit or just manually unpacking the installer is a step,
                                        but the real problem is the jungo driver is embeded in the exe.
                                        you need to unpack it or corrupt it in some way.
                                        or maybe replace it if the newer one is smaller.
                                        but i doubt it's smaller.
                                          Re: xp48 programmer
                                          Yes the drivers are embedded in the installation file, but here's 2 ideas:
                                          - use the well known install shield unpacking tools (to be concise look here) (didn't check if mention unshield ).
                                          { cab files are 49536328 ISc( signature; CAB, HDR; Install Shield v5.x or 6.x compressed file }
                                          - Install the installation file but don't close the last dialog! First take a look under folders:
                                          \user\current\AppData\Local\Temp\{F4B3F755-2E4E-46BF-A27D-2AF95FC6FD01}\{53CE7A2F-3A57-40BE-9AC6-0E331CA6AC96}
                                          C\Windows\system32\Drivers\LTKP*.sys
                                          ALL drivers are there
                                          Last step:
                                          Put the drivers on their right places and register them.
