Question about capacitor size with same rating
  • Nier
    • Aug 2020
    • 5
    If the capacitor rating is identical but if the replacement capacitor is smaller in size, does it matter?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Question about capacitor size with same rating
    If by "rating" you mean capacitance and voltage, it often does matter, because the temperature, impedance, and ripple current rating often matter a lot.
    On the other hand, if you are comparing a 30 year old capacitor and a 2021 manufactured capacitor of the same capacitance, voltage, temperature, impedance, and ripple current ratings, the newer part might be smaller, due to technology progress.
    PeteS in CA
    • Nier
      • Aug 2020
      • 5
      I'm looking to replace Rubycon 2700uf 6.3v MFZ series and 1500uf 16v MCZ series on an old xbox 360. I couldn't find a datasheet for either rubycon series. Which capacitor brand and series is appropriate for a game console? Would a capacitor labeled for general purpose and with low impendence work?
      • AleXis6
        • Feb 2021
        • 69
        • Belarus
        just some information here
        https://www.badcaps.net/forum/showthread.php?t=26134
        https://www.badcaps.net/forum/showthread.php?t=18911
        https://www.badcaps.net/forum/showthread.php?t=53198
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          Yesterday, 12:14 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Per Hansson
          Motor run capacitor physical size vs voltage rating & measurements?
          by Per Hansson
          (TL;DR skip the first paragraph)
          I encountered my first dead motor run capacitor at a customer this week.
          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
          (Unless a servo motor makes more sense that is).
          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
          The pump would run but sometimes trip the 10A breaker.
          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
          Then it could...
          09-20-2020, 06:32 AM
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
