replace 100v 100nf ceramic capacitor with 50v 100nf
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    can i replace 100v 100nf ceramic capacitor with 50v 100nf in an amplifier it will be safe?
    • 31131
    Re: ceramic
    that depends on the voltage being put into it.
    the 100v / 50v is the maximum the cap is designed to handle.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Re: ceramic
      The suitability question may be more than what DC voltage the part can withstand. Depending on the type of ceramic dielectric, specifically its temperature and voltage coefficients, the applied DC voltage may affect the part's capacitance. "COG" would be unaffected; "X7R" can be affected as much as 10% or 20%; "Y5V" or "Z5U" can be affected (reduced) by as much as ~80%.
      PeteS in CA
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        Re: ceramic
        thanks for answers guys was very helpful.
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Is it possible to test small ceramic disc capacitor with analogue meter?
          by chth96
          I read EBOOK of Testing Electronic Component and found that
          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
          Is it really possible to test small ceramic disc capacitor with analogue...
          03-09-2024, 10:03 PM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
        • NuclearSpartan
          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
          by NuclearSpartan
          Hi everyone,
          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
          I don't see any other visible damage anywhere else on the board....
          11-14-2024, 02:32 PM
