Milwaukee M12 M18 charger repair
  • BigPete
    • Jul 2012
    • 76
    • New Zealand
    Thought to post up a repair I recently did on two of these chargers.
    After replacing U1, TOP256EN, which seems to be a common failure and one I've done multiple times, these two ICs blew again, not instantly, but upon removing and reinserting the battery.
    What I found was the snubber circuit had failed.
    So after replacing U1 again, along with a resistor, polyester cap and a diode, all was well.
    The parts and locations:
    Replaced U1 - TOP256EN
    Replaced D2 - 600V 1A Diode
    Replaced C5 - 630V 4.7nF Polyester Cap
    Replaced R12 - 68khm 2W resistor
    Hopefully someone finds this info useful.
    • Jul 2011
    • 6070
    Re: Milwaukee M12 M18 charger repair
    “O” crap I have several of these chargers what wil be next to take a shit
    How old are these chargers ?
    Thanks for sharing your repair on these chargers
    • BigPete
      • Jul 2012
      • 76
      • New Zealand
      They were older models going by the dust in them.
      They regularly come up on the local buy and sell sites. All the ones I've repaired have had the U1 chip fail, except for one, which was a faulty plug, and I ended up replacing the U1 IC first thinking it was that.
      It could be a similar issue similar to the C4 cap in Yamaha amps.
      On these two chargers, the cap was out of spec and the resistor open. I replaced the Diode just to be safe.
      It'll be just another thing to check.
        • Jul 2011
        • 6070
        I am having an issue with one of my M18 volt batteries it is flashing all 4 fuel gauge light at the same exact time randomly and unpredictable times
        I am not sure exactly what going on with this error I know what it means when the M12 battery pack does this is because the battery voltages are not balanced anymore and the battery pack has come to the end of it life and I suspect that might be the case with this battery pack as well but I will not have time to investigate this issue until next weekend
        Sometimes when the M12 tool does this it because the fuel gauge meter is having some type of issue because when you put the same battery in another M12 tool it does not do the same thing because I have one M12 tool that flashes all four LED most of the time when you first put in the battery pack
        • faraday28
          • Jan 2022
          • 15
          • Indonesia
          Check output diode, Optocoupler and cap beside the transformer.
          If the transistor blow up, could be several factor including Output diode shorted.
          If snubber goes blow up, maybe the optocoupler failed to make main transistor turn off so the energy goes to snubber, or the cap for "balancing" the transformer worn out (look at C10 and their friend) the cap usually use high voltage rating 1KV or 2KV or use safety Y Cap.
            Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
            by sam_sam_sam
            I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
            So I have put them on the battery testing machine to drain each battery cell down to...
            09-04-2022, 04:45 PM
          • Petr0x
            Bosch 12V and 18V chargers modification
            by Petr0x
            Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
            You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
            Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
            05-24-2024, 01:00 PM
            ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
            The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
            configurable for operating as either a Hybrid Power Boost (HPB)
            charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
            4-cell batteries. Both configurations allow the battery to work with
            the adapter together to supply the system load when it exceeds
            the adapter capability, referred to as system Turbo mode. HPB
            charger configuration reverse-boosts battery energy to the system
            bus to help the adapter provide the system power in Turbo mode.
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • Thomasraud
            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
            by Thomasraud
            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
            QUOTED
            -It works on charger (without battery connected-only charger)
            -It works on battery (without charger connected-only battery)
            -& it also works when plugged in battery & charger, but it's not charging the battery
            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
            and..
            QUOTE
            The IC cannot maintain the input current level
            06-28-2022, 06:47 PM
